anybody had this problem ?
  • MAXAMUS
    • 210
    Hi All
    Think Ive posted this here before but is or has anybody had a problem with the stock motor on lipo kinda juddering when throttle opened and not giving power then at other times i open the throttle and i get nothing have to quickly move throttle from min to max until it eventually bursts into life and takes off
    stock motor
    Etti 150amp ESC
    2x 2 or 3 cell lipo in series
    x642
    its doing my nut in trying to figure it out
    Maxamus
  • Meniscus
    Refuse the box exists!
    • 3312
    I had an issue with RF interference related to the stock ESC, but that wouldn't be the case with your setup. Have you mistakenly gotten the receiver wet? Perhaps try a different receiver, at least that's where I'd start.
    Hope this helps, but merely throwing out an idea. Otherwise, I'd try changing the timing on the Etti.
    Does it still do it unloaded, running on the bench?
    • MAXAMUS
      • 210
      Have waterproofed the Rx with spray its 2.4Ghz so there is no interference and Esc is set for 2/4 pole brushless anyone know the pole count of the stock motor
      i will get to the bottom of this lol
      Maxamus
      • Meniscus
        • 3312
        See here: http://forums.offshoreelectrics.com/...ead.php?t=4107
        It has 6 poles.
        • MAXAMUS
          • 210
          thanks Guys
          will change settings on ESC to 6 pole High timing and see if that's any better will report back at the weekend hopefully
          Maxamus
          • Meniscus
            • 3312
            We wish you all the best. I'd recommend putting a slightly smaller prop on if you have one, at least to start and test with. If you do have an issue with the motor, such as a magnet, then you might save your ESC by not using as large a prop. If it works, I'd say, bring her in and slap a larger one on! If you don't have a smaller one, just don't push your luck, bring it back to shore.
            But then again, I'm the conservative type!
            • MAXAMUS
              • 210
              Originally posted by MAXAMUS View Post
              thanks Guys
              well eventually got to the pond with above settings and have noticed a much improved Blackjack things were running better and even GPS at 3/4 throttle doing 49.5 mph need a bigger pond lol
              Maxamus
              • Meniscus
                • 3312
                I'm glad it's working out for your Maxamus!
