Drive Hardware Question BJ26
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1750
    Ok everybody I'm very new to this so go easy on me. I realize the stock steerable system on the Blackjack 26 is a very weak link. My question is..... Is there an advantage to having an offset rudder vs. an inline one? I like the one they sell on this site but it's been out of stock for some time.
  • Jeff Wohlt
    • 2740
    Go with offset. Also make sure the leading edge of the rudder is behind the prop. There are a ton of struts and rudders out there that will work on that hull.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • rockwerks
      • 772
      why does the leading edge of the rudder be behind the prop
      an RC rock crawler lost in a sea of boat parts.........
      • Jeff Wohlt
        • 2740
        BEcause in many situations (not all if far enough away) the rudder will introduce churned up water that then gets in the path of the prop and blow out!
        It does not have to be all the way behind but I like it at least equal to the middle of the prop or more. If you hull is wide enough then no problem but the BJ is pretty narrow.
        www.rcraceboat.com
        • blackcat26
          High Speed Junkie
          • Sep 2009
          • 1750
          Ok thanks a lot! What about the system thats on the nitro bj26? Is it worth looking into?
          • Steven Vaccaro
            Administrator
            • 8932
            The inline system should be instock within a couple of weeks. They have finally came off backorder from the manufactuer.
            As far as an offset system. You can buy the parts. There is a really good post in the blackjack section with many ideas.
            http://forums.offshoreelectrics.com/...ead.php?t=6681
            Steven Vaccaro
