broken u joint?
  • jlr3rd1
    • 240
    broken u joint?
    so has anyone had a problem with the Flexshaft w/ U-Joint: breaking ? i have had two break this week? running 2s 3700 lipos and a x645 prop and everything else is stock???
    2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
  • mtk
    • Jun 2009
    • 58
    that's wierd I run 5s and it doesn't breakwhere is it breaking and is your steering to extream and the u joint binding the. snapping
    • kookie_guy
      • 897
      that's a lot of prop. that'll be your problem. time to upgrade the drive or prop down to an X642. Even then you'll probably break it in time.
      • jlr3rd1
        • 240
        so is there an upgraded shaft????
        • kookie_guy
          • 897
          you'd have to go with all new hardware to get rid of the steerable outdrive. Fullers is a very popular choice.
          • jlr3rd1
            • 240
            ok thanks :) going to do something this just not working:)
            • mtk
              • Jun 2009
              • 58
              fillers is the best option I would read all fourms about the hardware because there are more then on option also the skater system
              • kookie_guy
                • 897
                this is a nice looking system too for a great price.
                http://www.offshoreelectrics.com/pro...prod=ose-80085
                • jlr3rd1
                  • 240
                  thats looks good but will it work because of the 3/16" Propeller shaft? instead of the 4 mm shaft?? or do you need to modified the shaft assembly ?
                  • kookie_guy
                    • 897
                    your x645 is 4mm? I thought they were 3/16.
                    • mtk
                      • Jun 2009
                      • 58
                      if the prop hole is bigger then the dog drive and shaft use the stock prop insert to make up the diffrence
                      • jlr3rd1
                        • 240
                        the prop shaft size is 3/16 so i have to use a shim that goes from 3/16 to 4 mm:) so that way it will fit my bj and sv :)
                        • jlr3rd1
                          • 240
                          here are asome pic s of my bj :)
