Deans connectors.....
  • Chewy6696
    • Apr 2009
    • 14
    I just melted a deans connector on my BL. I was only running 3600 nimh. Whats up with that? Batteries were very hot but the esc and motor were cold.
    Everything is stock. I have removed the tuperware and batt. trays. batteries are shifted closer to the transom.
    It was a hot day out but the water was cool.
    What other connectors can I use that will take the heat?
    Thanks.
  • Christaphason
    • Jun 2009
    • 107
    Its possible your batteries just could not dish out the power your boat was demanding
    • JimClark
      • 5913
      After how long of a run and what was the voltage of tha batteries after the run?
      Thanks.
      Billy Graham
      • Chewy6696
        • Apr 2009
        • 14
        The run lasted 6-7 mins. The deans plug on the port side melted. I have been using these batteries since I bought the boat last Aug. I didn't check the volts after.
        Any suggestions on different plugs to use?
        • egneg
          • 4759
          5.5 bullet connectors.
          IMPBA 20481S D-12
          • domwilson
            • 4411
            Sometimes the deans will get hot if they have corrosion on the tabs. This will increase the resistance and in turn will generate heat.
            Government Moto:
            • Eggy
              • Jun 2009
              • 152
              Never had this problem with my boat, connectors peak at around 100F when running 5S with an X642
              • Chewy6696
                • Apr 2009
                • 14
                I found these on Hobby King
                What do you think about these?
                • Chewy6696
                  • Apr 2009
                  • 14
                  or maybe these ??
                  https://www.hobbycity.com/hobbycity/...10_pairs_(20pc)
                  • kookie_guy
                    • 900
                    thats what you want
