What to do? moded apche 24
  • SweetZ28
    • 1535
    Well here she is ...Flex cable routed through stock rudder that's fixed in place and then added a pro boat turn rudder put a extra section of plastic behind the back of the hull wall to make the rear stronger... One thing now i am wondering if i should cut off the fin as show in the photo?...Or will this fin make it more stable in the turns?
    WWW.PPRSLOTS.COM
  • Jesse J
    scale FE enthusiast
    • 7818
    how does it run? it is probably how ever you like it to look. what do you want it to do? what speeds are you after?
    "Look good doin' it"
    See the fleet
    • SweetZ28
      • 1535
      Did not try it yet...I am probably going to put a brushless system in her and a motor of 3,500 or like 4,100 KV and probably a 40mm CF prop and run on 6 cell packs....Don't know how fast it will go and what motor will be better for this boat.
      It looks great though now with the rudder on!
      THANKS
      WWW.PPRSLOTS.COM
      • brad65
        • 172
        I'd stay with 2500-3000kv motor with 3s motor mine rips! What size flex shaft?
        Pro Boat Apache 24 Brushless, Thunder Cat 31
        AquaCraft SV27, AqauCraft UL-1
        • SweetZ28
          • 1535
          The KV will be for only 2s so that's why i need more... the write up is here with what i used read through the posts.
          http://forums.offshoreelectrics.com/...ead.php?t=1667
          WWW.PPRSLOTS.COM
          • Steven Vaccaro
            Administrator
            • 8932
            I would also run it first, before cutting anything off so you have an idea on how it performs.
            Steven Vaccaro
            • SweetZ28
              • 1535
              Yea that's what I am going to do.... I will probably run it and say wonder what it will do if i cut the fin off then i will cut it off and next time i will try it and go MAN I SHOULD HAVE LEFT IT ON!!
              WWW.PPRSLOTS.COM
              • brad65
                • 172
                SweetZ28, ya ever run her yet with the new setup?
                • SweetZ28
                  • 1535
                  yes it works ok but with the 3300KV motor it's a dog the rpm of the motor i was using the traxxas titan 12 is 26000 RPM my 3300KV is only 22000 RPM so it like a slug!
                  Think i need a 37ooKV to 4000KV maybe?
                  WWW.PPRSLOTS.COM
