my moded apache
  • SweetZ28
    • 1322
    my moded apache
    Well here she is ...Flex cable routed through stock rudder that's fixed in place and then added a pro boat turn rudder put a extra section of plastic behind the back of the hull wall to make the rear stronger... One thing now i am wondering if i should cut off the fin as show in the photo?...Or will this fin make it more stable in the turns?
    WWW.PPRSLOTS.COM
  • brad65
    • 162
    Sweet bro. I've done the power up grade thing so far I'm still running stock hardware and u can tell things are off center. Are u still running a brushed motor in her?
    Pro Boat Apache 24 Brushless, Thunder Cat 31
    AquaCraft SV27, AqauCraft UL-1
    • SweetZ28
      • 1322
      Hi yes i am but after i did the flex shaft mod the boat is smooth as glass no vibrations at all ...the stock unit made it sound like the boat was going to vibrate apart!!
      WWW.PPRSLOTS.COM
      • roadrashracing
        • 1462
        How has thisa worked?
        • SweetZ28
          • 1322
          Hi it works great i cut the bottom fin off now also.
          WWW.PPRSLOTS.COM
          • roadrashracing
            • 1462
            could you post a current pic
            • CMRC
              • Oct 2011
              • 3
              I would have gone for an entirely new strut but hey, if it works well and she tracks strait then sweet...
              • Bomber Z
                • Oct 2012
                • 24
                Should have used a BJ26 flexshaft with U joint PRB2812.
                • SweetZ28
                  • 1322
                  No need mine works perfectly fine.
                  WWW.PPRSLOTS.COM
