going brushless!!!
  • thegreat1
    • Jul 2008
    • 249
    here ya go man
    • FE Wannabe
      • Jul 2007
      • 626
      Looks good, can't wait for the handling results. Let us know how it runs!
      SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
      • thegreat1
        • Jul 2008
        • 249
        so i finally got to run the boat last weekend and well i need a bigger pond lol. i also need to do some tuning but don't know really know what needs to be done. when i get on the throttle the boat torque rolls real bab onto the right sponson and also a little to the bow. i moved the batteries back some and it helped a little with nose heaviness but not the roll. i only ran it for a few minutes because i got bored with the small pond. i think i am going to be taking a 2 month hiatis from the hobby until i get to virginia where i can have a good pond to run in.
        • onionvolcano
          • Jun 2009
          • 10
          try adding turn fins or trim tabs, those will probably solve your problem, and give it a cool look when you pull it out of the water
          • FE Wannabe
            • Jul 2007
            • 626
            #35
            Great1,
            I think your prop might be too big and that is what is causing the torque roll. I am running an Octura Y534 plastic prop on a Feigao 10L on 3S lipo and it accelerates really well and stays flat to the water. I am going to try a Y535 next so I can try a metal prop.
            • bluthndr
              • Apr 2009
              • 14
              #36
              ya thats the problem because when i ran mine with a x438 it rolled terribly. then i swap it with the y535 and it runs perfect!
              • koshokid
                • Jun 2009
                • 14
                #37
                The x435 seems to work best with my brushless Apache.
                • thegreat1
                  • Jul 2008
                  • 249
                  #38
                  i guess i will have to go with a smaller prop. when i first got most of the parts i was going on the idea that what works for the vj should with the apache because it is basically the same hull.. well i guess not.
                  • onionvolcano
                    • Jun 2009
                    • 10
                    #39
                    hey! I have a few questions, does the feigao motor have bullet connectors already installed onto it, and also what is the shaft size for the apatche?
                    • thegreat1
                      • Jul 2008
                      • 249
                      #40
                      no the motor didn't have bullets on it from the factory. and as far as the stock shaft i don't know. i bought the bare hull with full intention to go brushless from the begining
                      • onionvolcano
                        • Jun 2009
                        • 10
                        #41
                        Also does the 100 amp esc have bullet connectors?
