Proboat release new Blackjack 42" catamaran
  • jevmax
    Legend
    • Aug 2007
    • 368
    #166
    I have had no problems with the Zeee packs, but that means little. You find a very large range of product quality coming from Asian suppliers. Some guys will say they are great and last forever, while his buddy has a bad experience. Lipo pack quality is inconsistent, regardless of the brand.
    • Peter A
      • 1498
      #167
      Originally posted by UpliFT-RC View Post
      By installing these trim tabs you will be able to keep the front of the boat down..
      I seen guys on Youtube hit 70mph with this boat with Trim Tabs...
      One down and one to go!
      They look just like Pursuit trimtabs!
      • koen
        • Mar 2020
        • 366
        #168
        just TFL trimtabs just a few $$ more for the name
        • UpliFT-RC
          UpliFT-RC
          • Jun 2019
          • 126
          #169
          Here are the pair that I am getting ready to test out this weekend at the local lake.
          Medium Trim Tabs for Black Jack 42 2 per package Color may vary from product photo(s) SKU: OXM-00140
          BJ42'' / Miss Geico 36'' / TFL Hydro 35'' / Retrieval boat 30'' Tug
          Make sure you check out my Youtube channel -----> shorturl.at/ntFQ7
          • Yvon
            • Aug 2021
            • 1
            #170
            Hello all!
            I'm new here, new in boating as well.
            Veteran in Cars mainly, a bit of drone and heli and planes too.
            From France, Britanny.
            Just bought a BJ42, had it run in the Mediterranean sea last week, pretty good.
            Then for my 2nd run, It ran for 10 meters then nothing....
            Aster investigation: one battery got some water from previous run the day before, and 2 cells not really in good shape and one solder completely ruined... by salted water ...
            Of course, everything is waterproof except the batteries :-(
            My batteries:
            Questions:
            Can I use some hot glue to seal the batteries (wire holes)? Or do you have other options, like putting them in a sealed plastic bag?
            Now, with regards to the cooling system, on some YouTube videos, I can clearly see the water jet going out from the second tube in the tail. On my boat nothing, looks like the water does not come in the cooling path.
            I checked the entries and nothing is blocked, may be I am not going fast enough (was doing 75% throttle)...
            Also, when I first started the boat, plugged the batteries and then pressed the on/off button to power the boat on, or off, no issues.
            After my first run, the button was inoperative, nothing... had to unplug the batteries to power it off.
            The next day, when I plugged the batteries back, the power went on immediately without pressing the button. and will not power off when pressing it as well.
            Have you ever seen that?
            A day later it was ok, looks like the power button is not waterproof as well?
            Thanks!!!
            Yvon
            • 1coopgt
              • Feb 2019
              • 417
              #171
              Originally posted by ACKopter View Post
              One thing to consider on the batteries, if you run the batts down till the ESC hits the low voltage cut-off it is exceptionally hard on the batteries as the default setting is too low. I found this out on the very first run, don't think it caused too much problems but the batts were pulled down too far for sure and that can most certainly cause puffing.
              You do know you can set the low voltage cutoff so that you don't damage the batteries when it reaches LVC .
              • Sparky814_hawk
                • Aug 2021
                • 1
                #172
                Has anyone thought about aero add-ons to keep the nose down on this boat? I am thinking about 3d printing some front aero add-ons to see if it helps.
                I have literally run this boat wide open with only the prop in the water. Fun but when it blows over it sucks
                Last edited by Sparky814_hawk; 08-21-2021, 09:04 AM. Reason: Autocorrect on phone that i didn?t catch.
                • ACKopter
                  • May 2021
                  • 27
                  #173
                  Yes, thank you. I found out awhile back and have since reprogrammed my esc.
                  • 1coopgt
                    • Feb 2019
                    • 417
                    #174
                    Sorry AC I didn't mean that to sound quite so harsh. Glad you got it all set .
                    • ACKopter
                      • May 2021
                      • 27
                      #175
                      No worries, I didnt take it that way at all.
                      It's been quite awhile since I've had a run with the BlackJack. Lots and lots of rain in my area for an extended period of time has elevated water levels both in the river and local lake which has all but eliminated bank access so it may be a pretty good while before water levels return to normal and get out on the water again. Rivers are still above flood stage for several weeks now
                      • alvinm
                        • Feb 2012
                        • 77
                        #176
                        No need. A set of trim tabs keeps the front end down. Speeds of 70+ are a breeze.
                        • 1coopgt
                          • Feb 2019
                          • 417
                          #177
                          Hi Uplift do you have any more pictures (Close up) . Did you mount them flush to the bottom of the hull or up a little bit ?
                          • naveda_08
                            • May 2021
                            • 66
                            #178
                            Can you turn at speed with the trim tabs? I thought trims tabs were not very good for catamarans
                            • UpliFT-RC
                              UpliFT-RC
                              • Jun 2019
                              • 126
                              #179
                              Took off my Trim Tabs
                              I took off my trim tabs since its was dragging big time no matter what angle I had them set at so I removed the Oxidean Marine Trim Tabs.
                              This boat was not made for speed runs anyhow it was made for ripping laps anywhere from 45-55mph.....
                              I am sure you can make them work but for my speed runs I went out and bought the new v2 Miss Geico Twin Zelos..��
                              This a run w/ out my trim tabs and a brand new Dashboata prop...
                              • jevmax
                                Legend
                                • Aug 2007
                                • 368
                                #180
                                Looking good!!!
                                https://www.youtube.com/watch?v=q-ATYkj6lc0&t=120s
