Pre run setup for the esc using the transmitter it starts out fine but once i release the trigger to select item to set it will not let me pick a setting in just cycles thru the choices and all i can do is shut down the esc ???second this thing leaks water from every screw that pernitrates its hull.. lol and i did a check before its maiden run and tightened all screws i put it in mu hot tub without canopy and watched water dripping in at the ruder cable mount plates the stinger plates every plate in back had water dripping in. thats crazy for a 700.00 boat.
