I have a new Recoil 26 that has maybe 10 packs through it. Completely stock. Last 2 times I went out i take off from shore and within 5 sec the throttle cuts out. I let it back to neutral, and go again and it goes, but does the same thing. If I cruise around for a bit at 50-75% throttle I can then go wide open to my hearts content. Is the thermal cutout acting up in the esc that it would activate like this before I even go? Or is the issue both times I connected my battery about 3-5 min before actually going?
Weird issues with Recoil 26
I do. I have 4. 3 identical ones, one different. I wish I could say for certain it has done it to all of them, but maybe I have a bad one. They all check out fine. Just find it odd if I cruise around for a while things are fine then. I forgot to mention - the first time it did it, I had weeds in the prop (this is weeks ago) and I figured it heated up my esc. But this time I went from box to lake in 5 min and it did it.
So it's probably not a battery issue. For some reason the motor is drawing too much current. I'd shut off the LVC On your esc and get a separate lvc detector that plugs into the balance plug of the battery. They are cheap. I have had that issue before with non-stick upgrades. It's all stock so it shouldn't happen but try disabling the lvc temporarily.
