Veles 29 . Fine adjustments
  • batman53201
    • Oct 2017
    • 42
    I did a search and couldn't find anything. I started this thread for those that would like to share any adjustments they made to the veles 29 out of the box. I'm picking up my boat soon and want to get familiar with any adjustments that I should make.
    I'm also new to electric, so if theres anything I should know, feel free to let me know.
  • boatsrnew2me
    • Oct 2016
    • 474
    contact proboat/horizon and ask for the updated flex cable right away .or buy one .the included one has been known to break easy .madrcer has a veles thread ask him about setup .he has the fastest stock veles to date .
    • batman53201
      • Oct 2017
      • 42
      Already ordered 2 flex cables, but I will ask proboat for there updated one. Thanks
      • vinnyp
        • Mar 2017
        • 283
        Welcome to the Veles club. I think you will like running this boat. I see you already have good props and flex cables. Great starting point. I have not had the opportunity to test mine much, but I am certainly willing to tell you where I am at. I have been running my packs in about the middle of the trays, strut set at 1.25 mm and flat as can be. I sharpened the rudder but didn't mess around with the length. In my case, I had to turn the steering rate down on the radio to keep the boat from spinning out in turns.
        • batman53201
          • Oct 2017
          • 42
          Thanks for your input vinny. I guess I will understand the strut adjustment once I get the boat.
          • boatsrnew2me
            • Oct 2016
            • 474
            strut adjustment is usually done on a flat surface ,such as a flat table. then you measure the distance from the table to the bottom of your strut.like picture shows
            click on it to see larger version
            • batman53201
              • Oct 2017
              • 42
              pictures are always appreciated. makes it so much easier to understand things. thank you. So, while adjusting strut, is it done by just loosening screws on the mount?
              • boatsrnew2me
                • Oct 2016
                • 474
                yes , 2 bolts .then slide strut up or down as needed and re tighten . in my example i scribe d my positions so i could return to them if needed
                • batman53201
                  • Oct 2017
                  • 42
                  Looking closer, i noticed that. Good idea
                  • MADRCER
                    • Feb 2017
                    • 765
                    Dave,
                    Watch the below video starting at 2:35 and it will explain what strut adjustments do. If I were you I'd run the boat out of the box and see how it works for you. Rafael mentioned that he asked his team to set the strut at a certain position before distributing them. Also be weary of taking other peoples advice on props and setup because some setups are fast and work well for some, but might not work well for others driving style or water conditions. Not to mention you could burn up a motor or ESC with a "setup that works well for someone else". Below is what I suggest on top of what I have already told you as for as the set up goes.
                    1. Look for and clear any Aluminum debri or burrs that may exist inside the rudder water intake canal that could restrict water flow.
                    2. Change out the steering servo soon because I know of three boats that it has failed on resulting in a crashes. I just used a spare Zelos 36 Spektrum S605 and it's working fine so far. It is a relatively cheap waterproof servo and if you want to try it you can buy it here. https://www.horizonhobby.com/9kg-ser...l--23t-spms605
                    3. If you do feel the need to raise the strut don't raise it much, because it will easily flip at 55mph with it too high.
                    4. Change to the kfxguy flex before you even think about putting your dasboata prop on it.
                    5. Don't run your batteries below 3.7volts per cell, if you want them to live a long healthy life.
                    • batman53201
                      • Oct 2017
                      • 42
                      I'm going to run it stock out of the box before I change anything. Thanks for the help
                      • batman53201
                        • Oct 2017
                        • 42
                        anyone know who I should contact to get an upgraded flex shaft from pro boat? Ive tried a couple people but didn't get a response
                        • Clintnz
                          • Jan 2018
                          • 4
                          productsupport@horizonhobby.com
                          • batman53201
                            • Oct 2017
                            • 42
                            Thanks. Got it today
                            • rw442
                              • Aug 2013
                              • 121
                              Just picked up my new Veles today wanted to ask about prop strut and other setup tips before first run. Have also purchased upgraded drive cable and couple from OSE store and pair of evoletric 2s 70 c 5000 mah batteries plan on sharpening and balancing stock prop for starters any other help would be greatly appreciated I currently own 2 Blackjack 29 cats one is all stock and the other is modded with 150 Esc and leopard 2200 kv 4074 also have a Impulse 28 modded with dynamite 120 Esc and leopard 4074 2000kv. Thanks
