Gps
  • CharlesR
    • Dec 2017
    • 29
    Gps
    Any suggestions on a GPS it would solely be used to record speed runs
  • MADRCER
    • Feb 2017
    • 761
    Check ebay for a Garmin Forerunner 101,201,or 301. Or the dynamite gps linked below.
    • Bp9145
      • Jan 2016
      • 1466
      I have both the Garmin Forerunner 101 and the 201 and it seems the 201 picks up the satellite signal faster. Also I've put both in the same boat and sometimes they were off with each others readings as much as 2mph. Usually with the 101 less than the 201. So I would go for the 201 as it would give you higher speed readings. . and that I like more. LOL. and as Mark indicated you can get them on eBay for a great price as these are older models.
        • 4335
        I use the Forefunner 201 and 301 models. The 201 uses a proprietary charger and the 301 charges straight from mini-USB.
        • CharlesR
          • Dec 2017
          • 29
          Thank you everyone
          • CharlesR
            • Dec 2017
            • 29
            These are runners watch's is that correct
            • boatsrnew2me
              • Oct 2016
              • 474
              no ,not watches persay . wearable yes ,would i consider it a "watch" no .
              https://www.ebay.com/itm/Garmin-Fore...YAAOSwPypaTvVI
                • 4335
                Yes, the Forerunner 20X series was the original design from Garmin as a wearable GPS device, promoted to runners, hikers, and bikers. The velcro wrist-strap is removeable with traditional watch band spring loaded pins.
                • dethow
                  Wired Racing
                  • Oct 2014
                  • 1500
                  RC BoatBitz out of AUS has some new tech you could consider. It's real time telemetry with GPS. All waterproof for use in boats and sends data back to Android device in real time with average and top speed readings. I think these would be nice for speed runs as you'll also get real time reading on motor, esc and battery temps.
                  I bought a couple of these to test this summer. I'm really surprised by the small light weight components. Garmin 301 weight is 2.3 oz while all components for this system total in at 2.4 oz. That includes sending unit, GPS unit, and all sensors. Costs $77.50 USD plus shipping from AUS. OSE sells these for $65 but out of stock for some time now. OSE's additional images show the nice read outs you get.
                  Only real drawback compared to a Garmin is that you need a different system for each boat and/or setup for easy transfer. But I think it would take unwanted time no matter what to transfer all components from one boat to another.
                  http://www.rcboatbitz.com/index.php?...oducts_id=2629
                  https://www.offshoreelectrics.com/pr...prod=ose-83279
                  Have fun with that....
                  • CharlesR
                    • Dec 2017
                    • 29
                    I did not mean to refer to it as a watch .I meant it's wearable which was just a way of describing it .I'd just like to know if it will work Thanks
                    • MADRCER
                      • Feb 2017
                      • 761
                      Charles, Yes the Garmin Forerunner series work well in boats, as long as they aren't made out of carbon fiber. See below pictures of both units.
                      102417 Zelos 90mph.JPG geico 77.8 mph run 2 9-24-17.JPG Veles 29 77mph pic in boat.jpg
                      • NativePaul
                        Greased Weasel
                        • 2764
                        There is a big difference in the watch style GPSs and the much bigger but still wearable devices. All the watch styles only ping the satellites at 1hz to save their tiny battery, whereas most of the bulky wearable ones like the garment above ping at 10hz.
                        dethow, does that telemetry system save a log of the run to the phone as well as showing live data? I have always seen loggers as much more useful than telemetry as I can't look at data and drive at the same time.
                          • 4335
                          Agreed.
                          Not to split hairs, but the Forerunner 101, 201, and 301 were the first watch style units. The reason they didn't look as much like watches or run on actual watch batteries as the models do today, was because the technology wasn't there at the time.
                          • CharlesR
                            • Dec 2017
                            • 29
                            Thank you for information
                            • dethow
                              Wired Racing
                              • Oct 2014
                              • 1500
                              I haven't used them yet... but from what I've read and seen on OSEs additional photos it shows live data AND logs with both average and max for speed and temps.
                              Understood that no one can look at data and drive at the same time... but it'd be nice to be able to check out your speed and temps right after making a speed pass. And be able to see when your temps have dropped to a safe level for your next pass.
                              As for oval racing... I'd like to stop my boat after a lap of testing a new prop to see what speed was and where temps are without having to bring it in and untape. If speeds look good and temp looks good... now I'll throw down a few laps, stop and see where temps got to. This could reduce testing and setup time dramatically.
