Zelos 36 First Run tips??
  • Thunder29
    • Apr 2017
    • 155
    Make sure you have a recovery system!!!!! Just in case something goes wrong.
    • Lowroller
      • Jan 2019
      • 8
      Of course! I either bring my kayak or paddle board...
      • Lowroller
        • Jan 2019
        • 8
        I want to change my props to the abc 1716-17/45 but can only find the right hand rotation in stock anywhere. Would it be ok to use that prop with the stock UL-19 prop PRB282047 which is left hand rotation? From what I’m reading it sounds like it’s the same prop as the abc 1716-17/45.
          • 4338
          No, don't do that. It's not the same prop, it's a copy, and generally very similar, but not the same. The 1716 prop is very popular and often out of stock. If Dasboata (Chris Hoffmann) doesn't have any, you could try Bonzi Sports in Carmel, IN.
          • Lowroller
            • Jan 2019
            • 8
            Ok, thanks. I emailed Chris.
            • Lowroller
              • Jan 2019
              • 8
              Mine needed to be programmed as the LVC was set way too low from the factory at 3.0 v per cell. I did mine with the transmitter and it was easy. I run mine on 2 6s packs as i have plenty of those for Flying EDF’s and it works well for me. If you want to run 6S with the supplied adapter I believe you would need 4-3S packs to achieve that voltage. As far as the other questions someone else can probably chime in for that as I left all mine in in place as it came from the factory.
              • dasboata
                • Dec 2010
                • 3972
                DID ,we communicate yet ?
                • Lowroller
                  • Jan 2019
                  • 8
                  Yes
