Leak in Prop Liner
  • mikiek
    • Apr 2017
    • 191
    Leak in Prop Liner
    Zelos 36, stock stuff tube, stock liner, OSE cables - This is strange. I was just preaching to Vinny to put his boat in a tub to see if any leaks could be detected. I've had a leak problem for a while so I did the same this evening. No motor running, just floating. It took about a minute but after that there was a steady drip (about every 2-3 seconds) coming from the liner in the stuff tube.
    1. I just lubed the shaft before doing this.
    2. The stuff tube is bent slightly upwards. The end is higher than water level. How the heck is water managing to rise above itself?
    3. The drip is so consistent it's almost like there was pressure pushing it thru.
    I'm stumped.
    May your batteries never fail you...
    Mike
  • vinnyp
    • Mar 2017
    • 283
    Unless the liner is wiped out, I would have thought the grease would keep the water out. When I tank tested the boat yesterday, the tubes stayed dry. Did you test the boat with lipos in it? That would make the weight right. As I said, I didn't do that. I will have to test it again after I get it back together. I am wondering if the end of the tubes are actually below the water line. A quick test would be to remove the flexes and place the boat in the water.
    • REDLINE1
      • 199
      I'm stumped.
      Did you remove your struts and remount them with silicon sealer?
      • CraigP
        • May 2017
        • 1464
        All of these current struts/stuffing tubes are "open flow" design, meaning there is no definitive seal in the driveline. When running, grease is designed to migrate towards the strut by the threading action of the flex cable. It then is lost through the static of floating bushings of the strut. So sitting in the tub, the water can go the other way. Mikiek, for the water to drip out the tube inside the boat means the water level has to be close the the end of the tube.
        I recently modified the back of my strut to accept a rod U-cup seal. The seal stops the grease loss while running, and keeps water out of the stuffing tube. Others have used sealed bearings in their struts, but they would need to have the outer races Locktite Blue'd in there to pass a static water leak test.
        Some guys use a piece of silicone tubing on the stuffing tube up by the motor coupling. That works great, but my data logger shows that it adds a lot of resistance to turn the shaft, and my current goes up with a slight loss of speed. The U-cup had no power loss. I imagine a sealed bearing would be slightly better...
        • mikiek
          • Apr 2017
          • 191
          I have never taken the struts off. Vinny might be on to something - maybe the tube is worn? I did have a cable break in the tube once, maybe that did some gouging on the Teflon. Unfortunately I don't have a spare so I'll have to order.
          From inside the hull I can see that the brass tube goes to the transom wall and I would suspect thru the transom and into the strut for some distance. Does anyone know how far the liner runs? Does it extend out of the brass tube inside the strut?
          What gets me is the constant drip - almost the same as when you don't turn a faucet off all the way. A random drip here and there I would write off as normal but this is weird.
          Mike
          • REDLINE1
            • 199
            I'm running wire drives. There .078 dia .So I get no seal between wire and Teflon liner from the grease and I have no water leaking in . The strut mount surface on the hull is not 100% flat plus it mounts flush with the bottom of the sponson . There's not much room in that area a seal to be made. I would take the struts off and remount with silicon. when you re installing them keep your cables installed to hold the alignment while your tightening the strut mount bolts
            • vinnyp
              • Mar 2017
              • 283
              Mike,
              Here is a picture of mine, when I tore it down for the transom plates I made up. The teflon liner doesn't come out last the back of the tube.
              • mikiek
                • Apr 2017
                • 191
                Thanks Vinny - that's a big help. Man how did you manage those screws? Especially the nuts on the inside? And good for you for taking pix while it was broken down. I need to start doing that.
                Mike
                • mikiek
                  • Apr 2017
                  • 191
                  You know now it is all coming back to me. The joint where the strut mounts to the transom has been spewing grease since day 1. I guess I probably should make an attempt at sealing that up.
                  Mike
                    • 4335
                    I sealed mine with silicone without completely removing the nuts from the screws on the inside. Just loosened them up enough to create a gap. I used clear bathroom silicone and it stopped all of my leaks from the back end of things.
                    • mikiek
                      • Apr 2017
                      • 191
                      I remember doing that only on the starboard strut. Right now it's the port tube that's leaking. I'm trying a gasket I made from some sheet rubber. Cut a small square then set the transom end of the strut on it and trimmed around the footprint. Cut holes for screws and shaft. Floated the boat in the tub again - no water. At least after 5 minutes. Ya'll have no idea how long that has been plaguing me. Every race, 3-4 oz of water sloshing around. It never shorted anything, but you know it wasn't doing any good either.
                      Thanks everyone!
                      Mike
                      • vinnyp
                        • Mar 2017
                        • 283
                        Man how did you manage those screws? Especially the nuts on the inside? .
                        I stood the boat up on its transom. Leaned the bow up against the wall, then used a long needle nose pliers to set the nuts onto the screws, while turning the screws with a 2.5 mm allen wrench. Cursed a few times when I dropped the nuts in the hull, but I got it done. I posted this picture before, but here it is again.
                        • REDLINE1
                          • 199
                          Ya your gonna invent a few new swear words trying to get the strut bolts in and out.. Its like building a ship in a bottle LOL. I use a hemostat clamp to get the nuts off then a small socket with a universal joint with an extension to re install
                          • vinnyp
                            • Mar 2017
                            • 283
                            Cant say that I have access to a hemostat. Long needle nose is all I have. Yes, after I got the nuts started, I tightened them up with a 1/4" drive swivel socket.
                            BTW..... I have been a mechanic for too many years to admit to. I don't think there are any new swear words for me to invent. I have about used them all up!
                            • REDLINE1
                              • 199
                              Lol u must have invented a lot of swears then lm still able to come up with a few new ones
                              You can get the hemostat at menards or ace hardware. Nice cause you can lock them on the nut.
