Zelos 36 strut adjusting gauge
  • vinnyp
    • Mar 2017
    • 283
    I had some free time today and decided to make up a gauge to adjust the struts on my Zelos 36. I got tired of screwing around with using a straight edge on the bottom of the hull and using a hex key for spacing the struts. I made this little gauge up on my mill today. Works pretty well so far.
    • 4340
    Sell those. I'm first inline.
    • MADRCER
      • Feb 2017
      • 765
      I wouldn't mind having one either if they are put into production.
      • vinnyp
        • Mar 2017
        • 283
        I'll see what I can do guys. I am sure I can make a few of them. I do need to get some more aluminum stock though. I don't have enough to even make 1 more.
        • MADRCER
          • Feb 2017
          • 765
          OK...Let us know if you are able to make anymore you want to get rid of.
          • mikiek
            • Apr 2017
            • 191
            Very cool Vinny. Looks like you could have yourself a nice side business. Count me in for any extras.
            May your batteries never fail you...
            Mike
            • vinnyp
              • Mar 2017
              • 283
              The weather is not looking good for this weekend. I may be able to make a few of these up providing I can locate more aluminum stock. I am going to try to get some at Lowes or Home Depot tomorrow. However, before I make any of them, I have to tell you there is a flaw in this design. You will have to pull your prop for any setting other than 5.0 and 5.5 . Smaller than 4.0 and you will have to pull the flex shaft. As the gauge slides down past the end of the strut, it will hit your prop and eventually the flex shaft, causing inaccurate adjustments. Let me know if you are still interested. If so, I will ask you cover the cost of the material and shipping. If I have the time, I wont mind making a few of them up.
                • 4340
                I'm down for materials, shipping, and beer money. REDLINE1 made me a great gauge to set the struts even against each other, but this would be nice to eliminate the handful of rulers I use now, regardless of the prop and drive dog interference.
                • vinnyp
                  • Mar 2017
                  • 283
                  OK.... I will let you know when I have the material and time. Hopefully, this weekend..
                  • MADRCER
                    • Feb 2017
                    • 765
                    I'm down with that if the measurements are true.
                    • vinnyp
                      • Mar 2017
                      • 283
                      I don't have a cnc mill. I have to measure each step manually and set the mill accordingly. It will be as close as I can get it.
                      • MADRCER
                        • Feb 2017
                        • 765
                        Ok. Thanks.
                        • MADRCER
                          • Feb 2017
                          • 765
                          Got your PM. Info sent.
                          • vinnyp
                            • Mar 2017
                            • 283
                            I hope you guys get good use of the gauges I made up.
                            • MADRCER
                              • Feb 2017
                              • 765
                              Mine came today. The measurements are very accurate considering it wasn't done by a cnc machine. Thanks!
