Now I understand "Puff"
    • 4335
    #46
    The right, starboard, cable is the wrong one. Props on the Zelos 36 turn inwards and the cable winds should create a ^ pattern pointing towards the bow. ////// on the left side, \\\\\\\\ on the right. The left prop spins CW and the right prop spins CCW. Check to make sure your props are installed correctly as well. Regardless of cable direction, you need to verify that the motors are both spinning in the correct direction after replacing the ESC's. If one or both spins the wrong way, simply swap any two connections between the offending motor and corresponding ESC to reverse it's direction.
    • mikiek
      • Apr 2017
      • 191
      #47
      Originally posted by Tamelesstgr View Post
      Don't give up! It will be all the more rewarding when you get it right. Learning is part of the game, we were all newbies once, and we are all still learning really.
      It's becoming a pride issue now. Who's gonna win - the boat or me?
      I do have several more replacement flex cables. One set from ProBoat and one set from OSE. Those are showing me that the twist is different on each side - looking into the hatch from the stern the port goes \ and the starboard goes /. Strangely that seems backwards to me. If \ (the port side) spins clockwise that's going to twist open the cable not twist it tighter.
      I will pull the cables, get the right ones in place, relube and reinstall. Hopefully that will make her run faster.
      May your batteries never fail you...
      Mike
      • Tamelesstgr
        • Jun 2014
        • 1512
        #48
        So based on Ryan's note above you want the cables to lay this way:
        NEVER SATISFIED RACING
        Fine Design 32 V-Hull 4082+6s
        • zooma
          Local club FE racer
          • May 2014
          • 652
          #49
          Wow. Easier to draw on a white board than sketch in Paint or similar. I'll have to remember that.
          Ron - The Villages, FL
          • mikiek
            • Apr 2017
            • 191
            #50
            Thanks for adding bow/transom. I think that's where I was getting crossed up. I'm still confused with the 2 sets of cables I have. They both seem to be labeled incorrectly. They would have you think it's \ /
            Mike
            • mikiek
              • Apr 2017
              • 191
              #51
              Think I'm going to hang this post on the wall!
              Mike
              • mikiek
                • Apr 2017
                • 191
                #52
                OK - Inquiring minds want to know. If I can swap any 2 of the 3 wires running between ESC & motor, what do those wires do? I'm not arguing and it worked, I just don't understand why it worked?
                Mike
                  • 4335
                  #53
                  Forget the labels. Forget the stock cables for that matter and just install the OSE cables like the picture Tameless drew up. Make sure your props go on like this:
                  • mikiek
                    • Apr 2017
                    • 191
                    #54
                    Forget the labels
                    Sounds like good advise. Well she's ready to rock. Could be a day or so before I can put her on the water. I'll give you guys a break
                    Mike
                      • 4335
                      #55
                      Originally posted by mikiek View Post
                      Could be a day or so before I can put her on the water. I'll give my wallet a break
                      fixed
                      • stratus
                        • Dec 2016
                        • 110
                        #56
                        fixed
                        lmao
                        Genesis 36", Zelos Twin 36"
                        • mikiek
                          • Apr 2017
                          • 191
                          #57
                          fixed
                          I must be one of HH biggest donors right now.
                          Mike
                          • REDLINE1
                            • 199
                            #58
                            AAaahhhh!!! The thread that wouldn't die.....
                            Well this is embarrassing. It appears that both my cables have the same twist Man, what else can the kid do to screw this up What sucks is I replaced both of those with packaged (and labeled) cables. So apparently one of the cables was labeled incorrectly. Lesson learned there.
                            [ATTACH=CONFIG]151349[/ATTACH]
                            [ATTACH=CONFIG]151350[/ATTACH]
                            I suppose that could explain the dreadful performance on the water a few minutes ago? Full throttle and the hull barely got up to plane. I did recalibrate with no improvement. No heat inside but maybe I just got lucky. It was a short run.
                            Well it is time to relube the cables anyway. WHAT"S NEXT???
                            I know I must be coming across as a complete imbecile to everyone - I'm not that stupid
                            You may want to consider these wire drives from Jeff Wholt
                            No more worries about cables freying or putting them in the wrong way. Ive been running them on my Zelos and Spartin with great results. Just installed one in my Blackjack but I haven't tested it yet.
                            • mikiek
                              • Apr 2017
                              • 191
                              #59
                              Well Redline - I have a couple of spare sets at the moment. BUT given my track record I could be needing more in a week or two The wires do look like a nice alternative.
                              BTW - thanks for that paint recommendation. I found the same Testors color except glossy at a hobby store I use a lot. It's a better match than what I mixed up.
                              Mike
                                • 4335
                                #60
                                What's the Testors paint code, or part number? I'd like to pick some up.
