Made a strut adjusting jig for my Zelos. Used some aluminum bar stock Drilled and threaded a 10-32 Allen screw with a locking nut. I have it set at the stock 4mm now but it can be adjusted for whatever I want Looks like it will work on my Spartin as well. A lot easier than messing with the rulers
Strut adjusting jig for my Zelos
I would keep it long, and likely will as it is a stellar idea. I have been putting the boat on a flat and measuring and adjusting with calipers. Measure, move boat, adjust and so on.Originally posted by REDLINE1 View PostThanks!. Not sure if I should shorten it to cover only the rear two pads. On my boat the peak of the center pad is slightly lower then the first and third when I put a straightedge on it
Thanks for posting and I hope you don't mind me using the idea,
Shawn
Not at all hope it helps. I'm fairly new to boating so I'm sure I'll be on here asking many questions. That's what these forums are forOriginally posted by srislash View PostI would keep it long, and likely will as it is a stellar idea. I have been putting the boat on a flat and measuring and adjusting with calipers. Measure, move boat, adjust and so on.
Shawn
Mark
That's a great idea and beats my method of trying to hold a straightedge and scale while adjusting the strut.
As far as how long it is, I would shorten it to just the rear pads. According to the Proboat guy the boat only runs on the rear 2 pads.
http://forums.offshoreelectrics.com/showthread.php?54022-NEW-Pro-Boat-quot-ZELOS-36-quot-Twin-Cat/page3
See post #89 and #248
Sorry, I ain't smart enough to link to the individual posts.
It needs to touch only the rear two pads. The middle pad sits lower, if you measure across all 3. You want to set your trim off the pads that touch the water while on plane, which are the rear two pads.Rafael Lopez
Product Developer-Pro Boat
