  • Mxkid261
    • Jun 2015
    • 734
    #931
    Originally posted by Erroneous View Post
    Venturi effect dictates the flow as neutral. One outlet has a pulling effect. Think sand blaster or paint gun.... Agreed about too much heat there must be another issue.
    Never had luck splitters. When I built my cat last year I used a single rudder pickup to a nice CNC Y fitting. It would spit water out one outlet easily, and barely trickle out the other, didn't matter how it was hooked up. I threw that fitting away after its maiden run Lol worked like garbage.
    • Darin Jordan
      • 9446
      #932
      Alright... I'll post a mod... I guess doing it in this thread makes it "official"...
      I know everyone here is trying to "Hit" 70, or 80, or whatever... I'm more interested in KEEPING it there... :) Oh, and turning at those speeds...
      Darin E. Jordan - Renton, WA
      • Keagan-Z06
        • Mar 2016
        • 970
        #933
        Very nice Darin! Almost missed the dam at the top.
        • Darin Jordan
          • 9446
          #934
          Thanks.
          I think a lot of people forget that a lot of lift is generated from the TOP surface. Breaking up the air their can really help keep the nose down.
          If you watch the video of mine working over the 1/6th mile oval last March, you'll see why I'm doing this! And that's with a TON of angle in the struts, and rather "mild" props... Need to be able to lay-down full-throttle without blowing the nose off.
          • Erroneous
            • Apr 2016
            • 451
            #935
            Two outlets vs one I guess.
            • Erroneous
              • Apr 2016
              • 451
              #936
              [ATTACH=CONFIG]144731[/ATTACH]
              [ATTACH=CONFIG]144732[/ATTACH]
              [ATTACH=CONFIG]144733[/ATTACH]
              Nice. Tried the spoiler on top while running stock. Worked a little. Ill be trying out the dam underneath using a 1/4" dowel. Curious how this combo works.
              • Erroneous
                • Apr 2016
                • 451
                #937
                I'd be shocked if you have a 18" water stream Lol
                Im glad you're both amused and shocked. Lol
                • Team Lucas
                  • May 2016
                  • 300
                  #938
                  Wow, ok then, now uploading from my crapple ibone doesn't only flip 90* but goes full inverted.
                  try what ever button you have to push to take pic with on the right, or photo flips if you do it from the left,[at lease my I6 does]
                  Zelos 36 stock 68 mph
                  • Mxkid261
                    • Jun 2015
                    • 734
                    #939
                    Really wish they'd offer a bare hull in white
                    • Erroneous
                      • Apr 2016
                      • 451
                      #940
                      Would be awesome.
                      • Team Lucas
                        • May 2016
                        • 300
                        #941
                        No offence to anyone: but I thought this was a thread to the Zelos Twin RTR.. started out great with tweaking the RTR, but turned into, replace motors, esc's, and such. ??
                        • Keagan-Z06
                          • Mar 2016
                          • 970
                          #942
                          I suppose swapping motors, esc's props and all that is classified under that tree?
                          • paulfromtulsa
                            • Nov 2013
                            • 211
                            #943
                            This is the modding thread
                            • Mxkid261
                              • Jun 2015
                              • 734
                              #944
                              Ya it is called the "official modding thread" seems pretty clear to me that there will be post's about upgrading the boat Lol. Im sure people purchased the zelos knowing they would upgrade power system. Id buy a bare hull instantly to build if they offered white, the yellow doesnt do it for me
                                I agree. It's turned into something that I didn't want it to. What i created it for was;
                                -props. What props are working best for you.
                                -motors. You swapped motors, we want to know what you went with and how it faired.
                                -escs. You swapped escs, let's hear how they fit, they run cooler, you picked up speed...whatever
                                -mods. Cooling system. Rudder. Aerodynamic. You name it. If it's a modification that makes you boat better in some way...lets see/hear it.
                                -aesthetics. Cleaning up the interior, hose routing, decals, paint jobs. Let's see it.
                                What I don't want is problems with your boat. Warranty issues., whining...whatever. It's cluttering the thread for no reason. This because a hassle for other people that didn't start from the beginning and they have to sift through the bs. This isn't a complain thread or discuss problems thread. It's a MODDING thread created to help people get their boat to perform better or increase reliability.
