    I think someone told me, leave it with the tongue if you wanna get out the hole faster like a cannon or detounge if you want a smoother acceleration outta the hole and increase top speed.
    Correct. And less tongue generally will pull less amps.
    • Erroneous
      • Apr 2016
      • 451
      #812
      So, I noticed someone sold their stock motors. This should be good.
        • Sachaken
          • Oct 2015
          • 10
          #814
          Ok thanks, I will test with tongue first and look at the temps every minute. otherwise I need to find someone who can detounge my props
          • Team Lucas
            • May 2016
            • 300
            #815
            I Detounged my 447s, and have yet to have a day to try it. What I understand is you get the pitch of a larger blade, but more tourqe and less RPM. Detounge them and keep the pitch but run at a higher rpm, hence speed.
            Zelos 36 stock 68 mph
            • Banzee
              • Mar 2012
              • 189
              #816
              When you detounged , you get less area on each blade , so it is easier for the motor to spin the prop and you get more rpm !
              • Keagan-Z06
                • Mar 2016
                • 970
                #817
                Banzee, thanks for dropping in on my video. Didn't know that was you! Lol. On another note, has anyone noticed that their left stock flex cable is bent a little? I finally got the Zelos up and running using two older ESC's in the interim. Fired her up, right side spins like it has a bucket of butter pasted on it! Smoooooth! Left side is wobbly and has more play in the strut! Which in turn makes for some heavy vibration noises. Both props have been balanced before I noticed this and I thought just maybe it went out if whack when the Zelos went into hibernation mode, nope it wasn't! Another member told me not to worry too much about it but I'm wondering if the amount of play and bent shaft has anything to do with it. Shaft came bent from factory. I thought it was normal as I never use to get that kinda vibration noise. Front bearings on both motors were recently changed and I repeat the "play" it has is not fwd and bkwd, it is left to right, up and down in the strut! Think of it as a wobbly tire on a car.
                • Keagan-Z06
                  • Mar 2016
                  • 970
                  #818
                  Spun them just now without the flex in the left and its buttery smooth. The little joint is either binding in the strut or its worn enough to let it have too much play.
                  • Erroneous
                    • Apr 2016
                    • 451
                    #819
                    My stock brass bushings in the struts wore out. Installed the octura lead teflon bushings and everything is wayyy smoother. You should pickup a set of OSE upgraded flexxes. Made a big difference.
                    • Keagan-Z06
                      • Mar 2016
                      • 970
                      #820
                      Yup, kfx told me about the OSE flex which I plan on doing. Still going strong in my Voracity. How difficult is it to change the Teflon bushing? Will running it as is cause problems? I just got this thing working after a month and would be salty if anything else went wrong. If I can't, then that's another 2 weeks without her.
                      • Erroneous
                        • Apr 2016
                        • 451
                        #821
                        At high rpm any vibration isn't good. Any problems? Cant say. Could last, could chatter and bind. Shaft snaps bye bye prop and possibly stuffing tube.
                        • Keagan-Z06
                          • Mar 2016
                          • 970
                          #822
                          Well in that case, she sits! Lol
                          • Keagan-Z06
                            • Mar 2016
                            • 970
                            #823
                            would it be this?
                            http://www.offshoreelectrics.com/pro...+%26+More&pg=2
                            • Erroneous
                              • Apr 2016
                              • 451
                              #824
                              Yes sir. A good 1/4" bit drillpress or vise. Carefull the bit will want to grab the brass/ aluminum.
                              • Banzee
                                • Mar 2012
                                • 189
                                #825
                                My pleasure !! We need to encourage each other !!!
