NEW Pro Boat "ZELOS 36" Twin Cat
  • Rafael_Lopez
    • Jan 2015
    • 470
    #61
    We recommend our Reaction 50c packs. If you can find good quality 35c packs, that's the minimum I'd run. Run for 1-1:30 minutes and check the pack temps. If they get over 130*, you will more than likely puff them. 100-120* is normal battery temp in this boat.
    Here are pictures of the flotation.
    Rafael Lopez
    Product Developer-Pro Boat
    • montymike
      • 786
      #62
      Sweet
      • Darin Jordan
        • 9446
        #63
        Been prepping mine to use for Q-Cat this year.
        One thing that is impressive about the factory boat is the quality of the steering servo. Specs are pretty nice for an RTR... Price is certainly amazing for this quality of a Servo!
        Specifications
        Size Category: Standard
        Type: Digital
        Torque: 161 oz-in @ 6.0V
        Speed: .24 sec/60 degrees @ 6.0V
        Bushing Or Bearing: Bushing
        Gear Type: Metal
        Because I believe in overkill for racing boats, I decided to give one of the new Spektrum S6230 Digital servos for mine. This will provide way more torque than is required, and also a faster transit/response time, which may (or may not) help in traffic or on an offshore course.
        The Spektrum S6230 Standard Digital High Torque Metal Gear Surface Servo from Spektrum, the leader in spread spectrum radio control.
        Size Category: Specialty
        Type: Digital
        Application: 1/10 Buggy, Truck, On-Road
        Torque: 311 oz-in (22.4kg-cm) @ 6.0V
        Speed: 0.14 sec/60 deg @ 6.0V, at no load
        Length: 1.61 in (41mm)
        Width: 0.82 in (20.8mm)
        Height: 1.18 in (30mm)
        Weight: 2.1 oz (59.5g)
        Bushing Or Bearing: Bearing
        Bearing: Dual
        Motor Type: Coreless
        Connector Type: Z-connector, removable
        Gear Type: Metal
        Gear Material: Steel, Aluminum
        Current Draw Idle: 9.8 mA @ 6.0V
        Current Draw Stall: 4900mA @ 6.0V
        Voltage: 6.0V
        Deadband: 4µs
        Darin E. Jordan - Renton, WA
        • Darin Jordan
          • 9446
          #64
          Prepped a couple of props to try on my "modded" Zelos 36. The big motors should turn these ABC 1815's just fine... :) Working on getting some additional sets of props to try as well. Taking this setup to the 2-LAP Time-Trial in LA next month. We'll get a chance to really wring her out there!
            [ATTACH=CONFIG]140966[/ATTACH]
            Those 1815's will move that thing well. I'm sure you already know, but in case you don't, they like a couple degrees negative on the strut or the boat will become an acrobat lol
              Specifications
              Type: Digital
              Gear Type: Metal
              [ATTACH=CONFIG]140863[/ATTACH]
              [ATTACH=CONFIG]140866[/ATTACH]
              [ATTACH=CONFIG]140867[/ATTACH]
              Type: Digital
              Bearing: Dual
              Gear Type: Metal
              Voltage: 6.0V
              Deadband: 4µs
              Man I love those servos. I have a few of them. I even have one in my 98mph Rivercat. Smooth, quiet and very powerful. For the price I don't think you can beat them. And they are waterproof! (Which with my luck means a lot! Lol)
              • Darin Jordan
                • 9446
                #67
                ... they like a couple degrees negative on the strut or the boat will become an acrobat lol
                Yes... I figured. I'm thinking these will work well on my Cheetah, probably at Neutral strut.
                Going to be running my Cheetah in P-Cat, and the Zelos in either Q-Cat, or T-Cat. The later depends on what Rafael is going to be doing. If he can make it out, I'm going to make it my mission to help him get the Q-Cat record. If he does that, I'm going to run mine as a T-Cat (6-10 cells, up to 12,000mAh).
                OH, question: Inwards or Outwards rotation??
                • Darin Jordan
                  • 9446
                  #68
                  Added a couple of "niceties", just for fun...
                  OSE Front "tow-hook"... these things are styling, and work great!
                  Also used an old Stiletto cowl screw mounted on the back of the hatch cover to help in the lifting off of the hatch. Just something I do on all my boats with this type of cover.
                  • Rafael_Lopez
                    • Jan 2015
                    • 470
                    #69
                    How the hell did you get your hands way up in there!?
                    Rafael Lopez
                      I seem to like inwards. (Left prop clockwise, right counter clock)
                      I think your absolutely right about the cheetah wanting it neutral. That think is hard to get the nose up. Don't forget, there is 1816's and 1817's too if you need more speed, but I think those 1815's are the best all around prop you can get. It's my favorite and "go to" prop. Brian and Jim hit the nail on the head with that thing!
                      • paulfromtulsa
                        • Nov 2013
                        • 211
                        #71
                        Any better eta on this rafael
                        • Yellow
                          • Jan 2016
                          • 81
                          #72
                          New guy here... I just pre-ordered mine yesterday! Can't wait!
                          • Rafael_Lopez
                            • Jan 2015
                            • 470
                            #73
                            The due date has always been mid March. Check the Pro Boat page for updates.
                            Rafael Lopez
                            • arrover
                              • May 2015
                              • 322
                              #74
                              Just got a shipping notification!
                              ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
                              • Rafael_Lopez
                                • Jan 2015
                                • 470
                                #75
                                Sweet!!
                                Rafael Lopez
