Great job Keagan!
NEW Pro Boat "ZELOS 36" Twin Cat
Not finished but will update as it comes alongProboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
Last edited by Keagan-Z06; 04-02-2016, 10:14 AM.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
Thanks man.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
I sure do! Looking good.Originally posted by Keagan-Z06 View PostDon't know why some of my pictures keep posting sideways. But you get the idea! Tomorrow it should be finished after stain, seal, varnish!
JPriami, notice anything here??
[ATTACH=CONFIG]142119[/ATTACH]
[ATTACH=CONFIG]142120[/ATTACH]
[ATTACH=CONFIG]142121[/ATTACH]Land, Sea & Air, A true RC Addict.
Well I'm having a heck of a time with these outdrives. The grease keeps getting sucked out as I drive. First it was leaking bad where the outdrives meet the transom. I silicone that area. Now I see its also getting sucked out where the adjustable part of the drive goes into the fixed area. I've only driven the boat on the lake 3 times now. It's causing excess wear on my flex cables also.
20160403_152817.jpgLand, Sea & Air, A true RC Addict.
Have you adjusted strut by any chance?Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
How do you guys use 3 straps when packs are all the way forward? Or is it just two?Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
It did this out of the box on the first run. I adjusted the struts maybe 0.5mm the 2nd run & it did it. No adjustments for the 3rd run and it did it.
I just removed both of them for inspection. It appears to be leaking from where the piviot ball screws into the long shank of the outdrive. It was really loose at that connection. That's where the bulk of the grease was & those threads were covered in it. Im guessing water passing by it at a fast rate creates a vaccum. Then the grease gets pulled out. I'll clean the grease and use a little locktite on reassembly.
20160403_161437.jpgLast edited by JPriami; 04-03-2016, 04:39 PM.Land, Sea & Air, A true RC Addict.
