Originally posted by Rafael_Lopez
View Post
NEW Pro Boat Impulse 31 V3
Kudos to you Rafael, and Proboat, for stepping up with some real improvements on these boats!My private off road rc track
I am working on sourcing better material for our strut bushings.Originally posted by montymike View PostLike strut bushings.guess should mention i have a mystic 29, 2 geico v1 and blackjack 29v3.
Thank you. Just wait until you see what is next.....Originally posted by kevinpratt823 View PostKudos to you Rafael, and Proboat, for stepping up with some real improvements on these boats!
Rafael Lopez
Product Developer-Pro Boat
Looking forward to this...Originally posted by Rafael_Lopez View PostThank you. Just wait until you see what is next.....
Will the ride pads on the Geico be any better? I know the old one really required some blueprinting to really take advantage of it.
Sent from my SM-G920V using TapatalkMy private off road rc track
Originally posted by Pedro Ramos View Postvery good product and good job Rafael Lopez, any plans on a bigger v or mono hull?
Rafael Lopez
Kevin,Originally posted by kevinpratt823 View PostWill the ride pads on the Geico be any better? I know the old one really required some blueprinting to really take advantage of it.
We are using different molds, the layup method is different, and the hulls are thicker. This combination greatly improved the ride pads on the V3 29-inch hulls. I feel there is no need for blue printing them; that's just my opinion.
Rafael Lopez
I will second that opinion. The new hull is definitely a more solid hull. Straighter and stronger. Any "blue-printing" that you'd feel the need to do would be more along the lines of getting that very last little bit of perfection out of the pads. Painting and such always rounds off corners a bit. However, it's a much livelier hull right out of the box and tunes in nicely.Originally posted by Rafael_Lopez View PostKevin,
I've been running mine right out of the box! (BJ29 V3, that is... same hull)...Darin E. Jordan - Renton, WA
Darin,
Have a V1 - purchased your fins from Steve awhile back. Improved cable & SM tabs too.
Question bout mounting position... as you know the stock fins have a leaned back \ rake look to them - hope that makes sense.
For yours - do they mount vertical?? -- Leaned forward \ rearward a bit?? Centered in the mounting holes?? Or for\aft a bit??
I've been wanting to ask these questions for a-while, this thread finally opened the door.
Please
Thanks...
Originally posted by Darin Jordan View PostA couple more notes:
1) Hull is from a new manufacturer. It's layup has been improved and the strength increased.It's a very nice evolution of the original design.
2) No Wood inside.
3) Sub-hatch has been eliminated
4) I believe that the flexshaft has been upgraded to be .187.
5) Still accepts OSE Upgrade Turn-Fins (and I would recommend those highly if you race or run in choppy water)
AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The Road
I push them right up against the hull, and the bottoms should be parallel to the keel line... I think that would make the backs about vertical, if I recall correctly.Originally posted by RCBoaterGuy View PostDarin,
Please
Thanks...
Slide them up in the mount as high as they can go also, to start with. That's likely where they'll stay.
0526031640.jpgDarin E. Jordan - Renton, WA
THANK YOU!!
Much appreciated
Originally posted by Darin Jordan View PostI push them right up against the hull, and the bottoms should be parallel to the keel line... I think that would make the backs about vertical, if I recall correctly.
[ATTACH=CONFIG]133849[/ATTACH]AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
I am not usually one for Black and Yellow on a boat but it came together nicely on this one!Why are you bothering me? I want to see your boat!
