ProBoat OutBoard Leg questions
  • SlickZERO
    • Dec 2013
    • 138
    Thanks! Looks like voltage isn't a problem. Just stay withing the maximum amps.
    Originally posted by revoltrunner View Post
    Here's the Leopard chart for the 3674
    http://www.leopardhobby.com/proviewe...=1&gid=70&pt=3
    Dumas Air Boat OS 25 nitro, Dumas Air Boat Brushless, Midwest Lobster Boat, AQ Lucas Oil Cat, Dumas Hot Shot IV Proboat outboard, Delta Force Cyber Storm 33
    • SlickZERO
      • Dec 2013
      • 138
      Thanks, I have 5 cell batteries from my airplanes. What kind of boat was it? Do you remember the prop?
      Originally posted by Luck as a Constant View Post
      With ease buddy.
      I ran the 3674 1700kv on 5s for years. It was a killer combo. 1400 would be better on 6s imo
      • SlickZERO
        • Dec 2013
        • 138
        Rtr?
        New to this. Don't know why this was moved to RTR Fast Electric Talk. I am building a Dumas Hot Shot IV wood boat, Proboat outboard, with Leopard motor.
        • SlickZERO
          • Dec 2013
          • 138
          Will the Leopard 3674 Motor fit inside the Proboat Outboard Motor cover?
          • Luck as a Constant
            Make Total Destroy
            • Mar 2014
            • 1952
            • SlickZERO
              • Dec 2013
              • 138
              Thanks, nice video. Looked really fast. Sorry I couldn't hear the prop size. My speaker is pretty bad.
              http://youtu.be/mYWeEdz-Keo
              • SlickZERO
                • Dec 2013
                • 138
                Does the shaft run in a teflon tube or just in the aluminum housing? Are the 2 little Allen set screws in the sides of the lower unit for injecting grease? Like with the Pro Boat grease gun?
                • shua
                  • Apr 2015
                  • 479
                  The stock shaft runs in a Teflon tube and the Allen set screws in the lower unit are there to let water out of the leg only. Many us us removed them and left them out.
                  • SlickZERO
                    • Dec 2013
                    • 138
                    Thanks for the information. I took them out and no water came out. There was a little grease on the tips of the Allen screws which lead me to believe there was no teflon tube. I remove the flex shaft after each day of running and the grease is kind of black but no water noticed. I think I will run with them in and take one out to check for water after running. It runs smooth and pushes an old Dumas Hot Shot IV 43 mph on 4 cells with an Aquacraft 36-56-1800Kv and a X442 prop.
