help with shockwave 26
  • okieman98
    • Jan 2014
    • 229
    i know this boat is slow can i but a different motor and still run 3s and use the same esc and make it alot faster it has the 1500kv motor and the upgraded prop from pro boat thanks
    1 motley crew- under construction 2x shock wave 26-2 x surge crushers - 1 30' mono
    I just bought a v3. I changed motor and esc and it's at 40mph on 3s right now. Same can be done with yours. I highly recommend just selling the stock motor and esc and get upgraded units. You need to add a little weight to it too. If you dont, it will not stay on the water. See this thread.
    http://forums.offshoreelectrics.com/...436#post606436
    • okieman98
      • Jan 2014
      • 229
      what kv motor did u use.
        2400kv castle 1415 with a seaking 120. Over kill maybe, but it runs very well and cool.
        • RCBoaterGuy
          • Dec 2014
          • 203
          So there's now two different version 3's??
          PB called this one version 3... http://www.proboatmodels.com/Product...ProdID=PRB0650
          Now your calling the new greenie version 3.... did I miss something??
          IMO they "should have" called the one above version 2 since that's what it is. Actually it's a rebadged IM26, but you already knew that.
          AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
          Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
          Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The Road
          • okieman98
            • Jan 2014
            • 229
            i think mine is a v2 or 3 who knows, i do like the new green. it came with the 1500kv motor and the 45 amp 3 s esc in white, i just looked to make sure. i been told to hang on to the 1500 kv because it will run 6s which i going to build soon. what motor upgrade can i do with this esc and what prop should i change to. trying to get ready over the winter. i will get one from hk(motor) any good suggestions
            • RCBoaterGuy
              • Dec 2014
              • 203
              Yours is the same as the two I have (1 brushed, 1 BL), technically it's version 2, but PB called it version 3.
              Started out to convert the brushed to BL, but never finished the project. Boxed it up & put it in the closet till I figure out what to do with it.
              Got BL version hull off eBay Aug 2014, put a 2000Kv motor in it w/Seaking 60A speedo, ran it on Sky-LiPo 3s 40/80C batts (22,200 rpm's) ran very very nice
              Bumped up the motor timing a notch and all hell broke loose, kept trying to roll over, to left facing the back. So based on that experience I'm gonna say that 22k~23k rpm's is about the limit for that hull. I was only running a 2-pole motor - had it on hand.
              Used the stock plastic prop on the maiden.
              Went to Leopard's website, couldn't find any 36mm 4-pole motors in the 2000Kv range. HK has a bunch of motors with gray cans, but 11.1 volts is the limit on them, 3s off the charger = 12.6 volts. So doubt if they'll last very long, on 3s anyways.
              So to answer your motor question... I'd look for a motor in the 2000Kv range, 4-pole if you can find one and run it on 3s.
              Regarding ESC's, check the motor specs... if (for example) it pulls... say 40~45-amps at peak efficiency, double that for overhead - IE: 90A Seaking.
              Regarding the 1500Kv motor, it will run 6s - BUT - that's 33,300 rpm's - from what I've read, 30k is the upper limit. 5s will yield 27,750 rpm's - nice improvement over the 1800 on 4s and you won't be running the motor at it's limit, food for thought...
                Well for some reason I thought they were calling it a v3, well I went back and looked and they don't call it a v3 or anything. My bad.
                  Used the stock plastic prop on the maiden. Sent my IM31 SS prop (it's the same as the SW optional prop) out for S&B and the place f'ed it up something good, not sure what to do now.
                  I haven't had an issue with any of them rolling. I had a 1512 castle in my v3 and it didn't roll. I've even used up to 52mm carbon props. I'm running a octura m645 on mine right now along with sometimes a 40mm 1.4 pitch cnc prop. This motor I have now is probably close to the 1512. Now my son's v3 acted a little funny on 4s with a big prop so he added some lead stick on weights to it on the right side rear and it fixed it. No idea why the right side, but it did straighten it out. Soon as I can get back to a pond I'll try it on 4s.
                  • okieman98
                    • Jan 2014
                    • 229
                    ok after looking at hk like u said going to have to replace them both. but just a thought if i could but this bl setup in a new hull maybe a different size to make it haul butt. so not just wast the guts, even if i had to sell it don't even know what to ask for them, ran the boat 4 times,
                    • RCBoaterGuy
                      • Dec 2014
                      • 203
                      About props....
                      Thanks for your help, it just looked so wrong compared with all the other props I have, specially the CNC props. It's Octura x642 for my IM31.
                      You mentioned a 40mm CNC prop... I have x438, x440, x442, x443 CNC props... any of those a good choice for this boat??
                      Mine was also rolling to the left (facing the back), that's why your puttin weights on the right. Reason?? The motor is rotating counterclockwise. Didn't have any probs with motor timing set to 7.5deg - the rolling issue started when I bumped the timing up to 11.25deg. Seaking 90A speedo, version 2.
                      I took my HW PB with me to the lake, timing change done at dockside. And it was the only change made. So obviously that's what caused the rolling issue. Sheer screw broke right after that, ended my day, didn't have spares, do now.
                      Check post #11 - I posted a free ' n' easy upgrade for the prop shaft & bushing - with a pic.
                      The shaft spins so much more smoother after that mod. Try it, you'll like it, trust me.
                        There's nothing wrong with that prop. I don't do mine like that but I had one done by ose that looked just like that and it performed pretty well.
                        Yes weight was added to the right because it was picking the right side up and pulling one way.
                        • RCBoaterGuy
                          • Dec 2014
                          • 203
                          How did you like your SW26 with the CNC x440??
                          I'm sure the CC motors your using have plenty of torque, would certainly explain why the right side is picking up.
                          I deliberately went a milder motor in the hope's of striking a balance between speed & handling, got lucky I guess.
                          Saw your posts & pix of the new green one in another thread (can't find it now) you were gettin 29.7mph in basically stock trim. Maybe slow by your standards?? But I'd be happy with 30mph, if I could get it there, specially having seen the results of a simple timing change.
                          I'm gettin one of those TP motors from Doug for my IM31. That boat was designed to go fast, so that's where I'll invest my dime & time for a speed demon. Accept the SW26 for what it is, single batt fun boat.
                            So how did you like your SW26 with the CNC x440??
                            I never tried the 440 cnc prop on my original shockwave or the new one. On the original I ran only carbon props. It liked a 48mm if i remember correctly. I ran a castle 1512 in it, which was downright unruly and uncontrollable on 4s. Did pretty decent on 3s.
                            The new boat I've run a cnc 443 and an m645 with the castle 1415. I like the 1415 much better, the boat is drivable and pretty fast on 3s. It does not roll or prop walk. It actually drives like it did stock. I did add some two part foam to the front because it had a little sheet of Styrofoam for floatation. ..which I doubt will float it should it fill with water. This new hull is stiffer. ..noticeably...and a little heavier. I did sharpen the rudder and the cnc prop for the next run. Should easily pass 40 on 3s and 50 on 4s....if it can handle it. I'll get some video of it.
                            In stock trim it do do right at 30 but the shaft was binding and then seized. I think it may have gone a little faster had that not happened. I still have the motor and esc that came in it....haven't decided what I'm doing with it just yet. Only has one run on them before i put the other stuff in.
                            • okieman98
                              • Jan 2014
                              • 229
                              thanks everyone yall have informed me on alot of info, i just may never be happy with this boat, because me need for speed and racing my son. so don't know it i want to spend any more money on it, if i sell it have know idea what it is worth, i like cats very much and want a hydro worst case i will turn it into a rescue boat. got to think on this some
