Mystic Cat Shaft Collet problem
  • john722010
    • Feb 2012
    • 46
    New Mystic Cat 29- Tried to remove the Shaft to grease and The Allen set screw was in so tight that I stripped the allen socket. I thing they used super glue not loctite. That said any suggestions for removing besided trying to drill it out? Also does anyone know what size set screw this is so I can get a replacement.
    Thanks
    JohnD
    I pulled the motor on my MG,slotted it with a dremel and heated the collet and then used a flat screwdriver
    • john722010
      • Feb 2012
      • 46
      Thanks, I'll give it a try.
