Gel coat cracking
  • roadrashracing
    • 1630
    Gel coat cracking
    I have a new proboat and the gel coat seems to crack really easy, is this normal?
  • driftah
    • 759
    yup all boats seem to sooner or later lol,the more rigid the hull is the less likely it is to flex and crack.hmmm I wonder if they use flex agent in any boat paints.....
    • roadrashracing
      • 1630
      it seems to be around holes and small areas, nothing to worry about?
        No not normal !
        Pro boat should warranty it and fix it,
        That should not happen to a new boat, I hear the hatch sucks to.
        Yes they should be using flex agents in the paint,
        But does not look like it.
        • stadiumyamaha
          • 1371
          the hatch does suck
          • roadrashracing
            • 1630
            Main parts, also one on the bottom, same kind of cracking by the rubber boot, hull is about a month old
              Like i said need to make some calls to pro boat big time !
              See what they will do for the buyers. ?
              And stand behind there stuff or not.?
              • driftah
                • 759
                ya contact them is best.even if they replace it which they should it may happen again.I have found that rtr hulls are prone to this issue but the more expensive hulls not so much ie delta force and mhz,aeromarine etc. upon a crash your hull is whacking off some form or shape of water and as we all know water does not compress or forgive much so the hull absorbs it.I hope in your case it may have been poor paint or a weakened hull in those areas...... good luck bro.
                • roadrashracing
                  • 1630
                  this is my first fiberglass hull new, it did blow over a few times and it has been used, I think I might just be being to picky. I will run it a few more packs and if it gets worst I'll call. I plan on painting during the winter anyway,
                  • martin
                    • 2881
                    Im afraid most hulls ( not just Proboat ) are to thin a lay up.
                    • roadrashracing
                      • 1630
                      called horizon, said I could submit but more then likely not becasue I tried to repair it, the crack on the bottom happened last week before all the other gelcoat cracking, so I just caed it.
                        No!
                        Tell them you would like corporates phone number.
                        And get names of Who you talk to.
                        Call corporate and make a stink for bad customer service.
                        In retail your just a number to them till you push some,
                        Sounds like traxxas, Blame the customer first then fix the problems.
                        Use your power as a customer with a voice.
                        • roadrashracing
                          • 1630
                          I also sent an e-mail with pics, see if anything happens that way, ran great again today with no more cracks.
                          • roadrashracing
                            • 1630
                            Got a respose back, basiclly I could send it it, it could be covered it could not be, I would have to pay the shipping to bring it there. Just to late in the season and not wanting to be with out a boat, Ill take my chances and hope it does not get worse.
                              LOL send it in when it cold out and you can not run,
                              Just make shore you get a claim number now and who you talked to.
