Mini Eco Submarined
  • skellyo
    • Feb 2010
    • 596
    Mini Eco Submarined
    Took out my brand new Mini Eco for a quick run this afternoon and the run was much shorter than I expected. I rolled on the throttle, it went about 40ft, then took a nosedive and submarined under water. I was worried when it didn't come back up, but it surfaced again after about 2 minutes. The bad part is that at a minimum, the motor is toast. The wires on it melted. I didn't have time to check the ESC yet, but from the outside, it looks intact. I'll check it out this evening when I get some more time.
  • martin
    • 2881
    Did water get in to short things out or some other reason.Martin.
    • sailr
      • 7128
      probably burned it up when it got buried in the mud and you used the throttle. If the prop can't turn, the motor and most likely esc will burn up real quick.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • egneg
        • 4759
        Hard to say ...
        IMPBA 20481S D-12
        • skellyo
          • Feb 2010
          • 596
          I let off as soon as it went nose down. My guess is that as soon as it went under water, it lost radio signal and it didn't failsafe to neutral and kept the throttle wide open (running a brand new Tactic Tx/Rx). It just sucks that it happened on the very first run.
          • skellyo
            • Feb 2010
            • 596
            Good news, the esc is still alive and kicking. Just tried it with another micro motor I have here.
