MiniCat Hydro speeds/setup.
  • nate
    • 1652
    Does anyone have Links to any Mini hydros like the carbon edition ect. going
    faster than 45mph? If so whats the setup esc motor prop and how many cells?
    Iv been thinking about buying one, there decent right out the box from what Iv seen.
    LMT
    LehnerMotorenTechnik.com
  • repsol
    • Jan 2011
    • 13
    Sidewinder tenth scale 4600kv 3s & 32x36 prop and 45 c Hyperion 1900mah
    • repsol
      • Jan 2011
      • 13
      Sorry here was a link
      • badag98
        • 190
        http://forums.offshoreelectrics.com/...ad.php?t=20661
        Have a stock one listed for sale!! Pretty quick out of the box.
        • electric007
          • Jul 2011
          • 53
          Sidewinder tenth scale 4600kv ok,,, but what esc.
          • repsol
            • Jan 2011
            • 13
            The sidewinder comes as a package I'm using the car speed control,
            I've used it with and without cooling plate
            And didn't notice any difference in temps.
            On another note the stock cable drive won't take all the power so I made a.048 wire drive with an Octura collet for motor coupling.
            Flex hex I've found to be more reliable than set screw couplers.
            • bracka69
              • 298
              Hey Repsol. What kind of prop are you running? Is it the stainless or plastic prop?
              Thanks
              • SloHD
                Slow Electric Addict!
                • Apr 2013
                • 337
                I would not run that setup on 3s. Way too much rpm, even for 2s... The hull is not fun like that. You want somewhere around 3300kv for 3s. The boat is money with a stock-ish setup.
                I run mine 3300kv, seaking 35a, with an x435 prop
                • bracka69
                  • 298
                  Thanks SloHD. I have 2 Micro Hydros, a first generation which is my boat to test different set ups with and a second generation CF which I have ran on 4s and it is wicked fast like that. In my test boat I just installed a TP2930 4100kv motor with a seaking 60A esc. Just trying to decide on what prop to use.
