Here is the BIG one and that is working with the brass sleeve bushing the stub shaft rotates on. I see many users asking about this type of system. This system has been used for MANY MANY years by the Nitro/Gas powered boats, and they have some VERY fast boats. If it has worked for them this long it will work fine for us on our FE powered boats. In theory the bushing is supposed to “float” inbetween the brass stuffing tube and the flex stub shaft. BUT, most importantly, there needs to be a clean/slip fit between the stub shaft (it’s rotating, fast) and the brass sleeve bushing (it’s the bearing surface). It needs to support the stub with little resistance, but also not have much if any radial slop. To date, I have never “worn out” a brass sleeve bushing in any boat I have ever owned FE, Nitro, custom build, or RTR. However, with these RTR boats you NEED to take the bushing out of the stuffing tub and make sure the sleeve bushing fits correctly.
First thing I do to check this fit is pulling the sleeve bushing out of the stuffing tube. I have found on these RTR boats that the sleeve bushing likes to “stick” in the stuffing tube. What I do for this is; I carefully chuck the shoulder end of the bushing into my cordless drill and using a green 3M scotch bright pad. This process isn’t going to remove much, if any material, but it will knock down any burs or sharp edges. The Key here is making sure you don’t deform the bushing in the chuck of the drill. Sorry, no pictures on this one. If anyone needs one let me know, I can reproduce the procedure.
