Chipped bottom...how to fix??
  • Flic
    • 3
    Hi all. I'm a new forum user as well as a new owner of a Supervee 27R. Love this boat as it is my first 'fast' rc boat. I just finished my 5th run on it and I must have hit something in the water as a piece of the paint layer about an inch long chipped off on the bottom. It did not go through the fiberglass but it appears it will likely continue to chip off. How would one go about fixing this?? I tried to submit a pic, hopefully it worked. Thanks for any help!
    Eric
  • dana
    • Mar 2010
    • 3660
    if it were me i would use some ca glue med. then touch it up with nail polish. easiest fix
    • egneg
      • 4759
      Ca only works when there is a lack of O2. Fill it in then place a plastic bag over the area to force it to cure. You may need to do this more than once depending on how deep it it is.
      IMPBA 20481S D-12
      • dana
        • Mar 2010
        • 3660
        i should have mentioned using accelorator
        • egneg
          • 4759
          That will work as well.
          IMPBA 20481S D-12
          • U1Racing
            • 62
            you could mix up 5 min epoxy and cabosil or micro balloons then fill in the chip spot with the mixture then paint over it with nail polish, it would be as good as new almost
            too much power not in the FE racing dictionary
            • Flic
              • 3
              Thanks for these suggestions! Since I have some medium CA on hand, I will give that a shot. I'll then see if my wife has any yellow nail polish I do have a bottle of yellow Testors enamel paint. Would that work as well? Not too concerned about an exact match since it is on the bottom.
              • wparsons
                • 461
                CA will cure in air, but it does require moisture/humidity to dry. Thread locker requires a lack of oxygen to cure though.
                Light travels faster than sound, so people may appear to be bright until you hear them speak.
