Failure to Start-Up the boat for the first time.
  • tankema
    • 1
    Hi,
    I just bought this bought the Supervee 27R RTR Brushless.
    I also purchased 2 5000 NiMH batteries as recommended with the current plugs.
    So i did as it said and placed the batteries in, turned on the transmitter/controller and then connected the batteries to the two deans ultra plug connections inside the boat. In the manual it says their will be a beep and you press down the throttle etc. I do not recieve a beep and it does not turn on.
    I have tried troubleshooting by binding the transmitter and the receiver, when i press the bind button, there is not any LED lights that flash or anything.
    I think there may be a problem with the connection between the batteries and the ESC.
    Any solutions?
    Thanks.
  • marqueeRc
    • 1
    Make sure your throttle trim is on nuetral..
    • dana
      • Mar 2010
      • 3660
      My throttle is set to reverse and turned all the way up. Try that
        • 7512
        When you plug in the batteries, does a light come on on the receiver? Does the rudder work?
        Is the polarity of the Speed Controller wire correct in the reciever?
