Waterproofing
  • Ramrod
    • Dec 2010
    • 28
    Waterproofing
    Hi guys, I'm a newbie to this and have had my supervee27R out two times now but am getting quite a bit of water in the hull. I can tell when the back end starts hanging low.
    I have siliconed around the canopy but I think water must be coming in elsewhere UNLESS this is normal.
    This can't be good for the electronics?
    Thanks!
    -Brady
    • 7277
    Get some hatch tape and most of your problems should be solved. Silicone seals never work well. Also, did you check all the hardware to make sure its tight...better yet, remove all hardware and put a bit of silicone on each.....put the boat in the bathtub and see where it maybe coming in.....put the batteries in while doing this to simulate the weight of the hull ready to run.....if theres water coming up the stuffing tube, then a bit of silicone tubing can be placed over the stuffing tube and the cable.
    • Ramrod
      • Dec 2010
      • 28
      Thanks buddy! I will do what you said and putting it in the tub is a smart idea.
      Where would you get some hatch tape?
      Also, does everybody pull out the motor after every usage and spray down?
      Thanks for the help - I've quickly found out that I need to run this thing at a bigger pond than my last boat, it rips!
      • dana
        • Mar 2010
        • 3570
        you can just use elctrical tape because its waterproof. i dont ever pull the motor out number 1. because its a PITA and 2. because unless its full of water you really dont need to. you can spray it now and again with some wd40 and youre all set.
        • hyrulejedi86
          • Aug 2009
          • 494
          I would recommend clear hockey tape over electrical tape because I've had it leave a residue and doesn't seal as well for me. I've used hockey tape ( from here on OSE or Dicks sporting goods) for a while now and it has never failed, left marks or peeled paint.
          • dana
            • Mar 2010
            • 3570
            ive never used the hockey tape, but i can tell you some rubbing alcohol will take residue off easy. plus home depot has electrical tape for .59 per roll. hockey tape is what like 10 bux or something? whichever you decide, tape is a good idea
            • Ramrod
              • Dec 2010
              • 28
              Good call, I have lots of hockey tape here at my house!
              So, you put in the batteries and tape it off and drive it. Take it off later and do it again next time. That should help, the boat handles bad once it starts getting water in the back.
              Thanks guys!
              • Ramrod
                • Dec 2010
                • 28
                So Dana, you just spray the motor and leave it in you say? That sounds good to me.
                What about the driveshaft? Are you pulling it out and greasing it every time like the manual says?
                • dana
                  • Mar 2010
                  • 3570
                  yes leave the motor, the sv motor is a pain to remove. as for the driveshaft i usually take it out and grease it every 3 runs. some guys do it every time but thats your call
                  • Ramrod
                    • Dec 2010
                    • 28
                    Do you have any other good tips? I really am a rookie at this but am understanding it quick. I am sure the metal prop is in my future.
                    I had the boat ripping it up today with some chop in a large pond. First lesson learned was to let off the throttle turning into the wind. She flipped and had to wash into shore...haha
                    • dana
                      • Mar 2010
                      • 3570
                      other than upgrading parts i dont have any more tips really. a prop would be a good place to start. try an aquacraft 40/52/3. also if you want the boat to get on a plane faster try a x440/2. 2 blade props have less top speed but get goin alot quicker. theyre better for small ponds.
                        • 7277
                        Theres a reason its nicknamed the Super Flip!
                        It is a fun boat......placing the batteries in front of the motor in a V formation can really improve the handeling is rougher and windier conditions. Are you running LiPos?
                        • Ramrod
                          • Dec 2010
                          • 28
                          Thanks for the help guys. I have 2 5000mah nimh batteries. I think they are a lot heavier than lipos but the hobby shop I got it from said they are good for a newbie like me.
                          I can't wait to try it when the water is like glass.
                          • Cedavis34
                            • Nov 2010
                            • 6
                            I did a bathtub test and found that my boat leaked on the transom around the stuffing tube. I sealed that with some Z-poxy, and then noticed that it only took on water when running. I suspected my water jacket, and it wasn't until I used vasoline on the o-rings when assembling the water jacket before I got that to seal perfectly.
                            When I ran the boat tonight, it was perfectly dry inside after about 5 minutes. I then ran it some more, barrel rolled it, and almost sank it because I didn't tape the hatch.
                            • rchuntlsl
                              • 122
                              always tape the hatch, even on a short run.
