Throttle/ESC problem
  • osprey21
    • 723
    Once I connect the battery packs and squeeze and hold the throttle trigger to arm the ESC (1 beep) then release the throttle trigger (3 beeps) the motor starts to run. It's not turning very fast but I can't seem get the throttle to close all the way. Adjusting the trim knob only brings it down somewhat.
    However it will stop running if I push the trigger all the way forward and hold it there.
    WTF?
    • 7512
    Try reversing the throttle, mines set to "R".
    • osprey21
      • 723
      Mine is set on R as well - will try the N position.
      Well.. it was even worse in the N position.
      • bill34207
        • Dec 2009
        • 2617
        It sounds like the esc is not recognising the neutal position of the radio as the off position.
        I'm guessing this is a SV27 motor & esc with a Tactic 2.4? Some radios require the throttle to be set in the reverse position and the Tactics come through that way. (Futaba requires reversing for use with an esc as well)
        With a Turnigy esc you are supposed to (on it's 1st use or when moved to a different radio) hold the throttle wide open when applying battery power, then after it beeps release the trigger back to it's neutral spot. This allows it to set it's throttle limits. Don't know if it will help with what you have (it may put the esc in programming mode so if you have a manual check it) but it's a thought.
        My YouTube Vids
        • osprey21
          • 723
          Originally posted by bill34207 View Post
          It sounds like the esc is not recognizing the neutral position of the radio as the off position.
          Yes sir.
          • bill34207
            • Dec 2009
            • 2617
            I'm really at a loss for an explanation on it myself. It's not the same as the esc that came in my UL-1 (which armed and worked like it's supposed to right out of the box).
            If it's a new boat you might want to take it back where you bought it. There may be something "not right" with the esc or radio. Otherwise you might check with Hippie or Hebner. I think both of them have SV27's
            My YouTube Vids
            • osprey21
              • 723
              Well I just tried it again and everything worked as it's supposed to.
              I think I had the throttle trim set incorrectly.
              danged newbie
                • 7512
                Duhhhhhh,,,,we've all been there at one time or another. Glad its working.
                • bill34207
                  • Dec 2009
                  • 2617
                  danged newbie
                  Doh!
                  My YouTube Vids
                  • osprey21
                    • 723
                    Whelp... I'm heading out to test-run the boat - wish me luck.
                    • wizard122
                      • 535
                      Check this out.
                      2 SV 27's and Vac-U-Pickle UL-1 Power
