need help!!! lots of smoke
  • 2ltrvtec
    • Jul 2009
    • 61
    so i got my 4s1p lipo today. i already wired the the esc for one pack and im running a receiver pack. i did evrything the way the tips n info section on here said. when i plugged evrything up to arm the esc smoke just poured out of it. i was told 4s was fine for the stock esc. can any one help me please
  • H&MWill
    • 623
    4S is fine. Do you have some pics of how you have it wired?
    Many issues!!!
    • z400
      • 1311
      Obvious wiring boo-boo
      Happen to remove the red wire from the 3 wires coming from the esc and going to the receiver?
      And there is no need to run a receiver pack with 4s.
      You would have been fine with leaving it alone, wiring it up for 1 4s pack and running it.
      Post pictures of everything inside your hull.
      Z
      KBB34" Mono - Fast
      ToySport Triton- Not as fast
      • Bill-SOCAL
        • 1406
        I'm betting reversed polarity or some type of short from"wiring" it up. All you really need to do to set up the stock ESC is to put a single Dean's ultra plug in place of the series harness that it comes with.
        Pictures will help confirm this.
        Don't get me started
        • 2ltrvtec
          • Jul 2009
          • 61
          its wired exactly how the tips n info page on here says to run one pack with a receiver pack. and yes i did clip the red wire from the esc to the receiver. the smoke came from the back of the esc around the wires that go to the motor but those were all hooked up right also. the boat was running on one nimh 6 cell pack ( slow as hell) wired the same way. i didnt change anything but use a 4s1p 25c 5000 mah lipo. im totally confused right now
          • 2ltrvtec
            • Jul 2009
            • 61
            thats how i wired it. i cant do pics i have an old school floppy disk digi cam with a laptop that wont take floppys lol
            • z400
              • 1311
              Floppy disc digital camera?
              Never heard of such a thing.
              Well good luck, cant provide much help at all with the information you have provided.
              Z
              KBB34" Mono - Fast
              • domwilson
                • 4405
                What about the battery side? Did you solder the connector on with the right polarity?
                Government Moto:
                • 2ltrvtec
                  • Jul 2009
                  • 61
                  yes sir. and yea its a digi that holds a 3.5" floppy disk its a sony mavica
                  • 2ltrvtec
                    • Jul 2009
                    • 61
                    thats the way its wired to the tee.
                    • domwilson
                      • 4405
                      So the Deans is wired like this,with the red on the positive on both connectors?
                      Government Moto:
                      • 2ltrvtec
                        • Jul 2009
                        • 61
                        yes on both the esc and the pack
                        • 2ltrvtec
                          • Jul 2009
                          • 61
                          i hooked everything up to go through the arming procedure. it armed i gave the throttle a tap to see if it was running and it revved then once it stopped, sooo much smoke. i unplugged the pack pulled the esc out right away and checked everything and im lost
                          • domwilson
                            • 4405
                            Is the motor good? Can you check?
                            Government Moto:
                            • 2ltrvtec
                              • Jul 2009
                              • 61
                              im not sure how to check it. the last time i ran it ( two weeks ago) was on 6 nimh cells and it was fine. unfortunately i over discharged that pack and it wont charge any more so i cant use it to check anything
