Lipo Bat
  • BBZRacing1
    • 33
    Lipo Bat
    Guys can you tell me what would be the best lipo bat. to use in my sv.Keep in mind that it has the stock esc & motor with a Graupner K Series 48mm
    prop.
  • z400
    • 1333
    Post this in the Fast Electric Rc Boating Questions and Answer Forum.
    Anyways, search for Zippy lipo's or turnigy lipo's over on www.hobbycity.com
    Look for 5000mah or more and no less then 20c discharge rates. You need a pair of 7.4v 2s lipos.
    Z
    KBB34" Mono - Fast
    ToySport Triton- Not as fast
    • 785boats
      Wet Track Racing
      • 3423
      It might be wise to drop the prop size to a K445 also. The K448 might be a bit big.
      If you can get hold of a metal Octura X642 you might find a bit more speed with less current draw. And I believe it will probably handle a bit better.
      Paul.
      • bwells
        • Jan 2009
        • 847
        z400 He posted this in the sv27 forum, That is what I would have done, is this wrong?
        Z400 is right, Just got 2 5000 Mah 7.4 20c batteries for 27 a piece and took 10 days from Hong Kong. Cheapest you will find but people say that you get what you pay for but I'm giving it a chance as I don';t race and am fairly conservative on them with my BJ26 EP and ran for 15 minutes and only put back 3758 Mah. Go to Z400 link and search. The charger is another story
        • z400
          • 1333
          Yeah, its fine to post it here but this is more of a general boating question and will get many more views and plenty more responses in the other section on the boards here.
          Z
          KBB34" Mono - Fast
          • slyman
            • Jan 2009
            • 126
            Lipos with stock ESC
            Be aware that the stock ESC does not have a low voltage cut off. You will fry the lipos if your not careful. Bring the boat in as soon as you notice it start to slow down if your going to keep the stock ESC.
            I would strongly suggest that you switch over to the ProBoat ESC used for the Black Jack with the programming card. You will need the card to program the ESC for lipos and low voltage cut off. I have run this set up for more than a season now with no problems.
            • domwilson
              • 4411
              Or you can get one of these... http://www.dimensionengineering.com/LipoShield.htm
              Government Moto:
              • e-JP
                • Jun 2009
                • 3
                or this : http://www3.towerhobbies.com/cgi-bin...?&I=LXPGN1&P=7
                • BBZRacing1
                  • 33
                  How about this lipo bat. trak power 2 cell 5400 mah 7.4v Would two of these do the trick?Thank you
                  • 6S HYDRO
                    • 1325
                    yeah if you want to pay 5 times the price for two packs- hobbycity all the way man you can almost get 6 pair for the price of two of those
                    • BBZRacing1
                      • 33
                      I here that they are junk,someone was saying that they aren't true.(meaning volts)
                      • domwilson
                        • 4411
                        Check out this thread... http://forums.offshoreelectrics.com/...ead.php?t=9394
                        Government Moto:
                        • scooterP
                          • Jul 2009
                          • 250
                          I using a pair of Turnigy lipos from them. 2s 5000mah, and they are doing great. I've had 5 full on runs with them and the batts aren't barely warm to the touch when I bring the boat in. I'm using a lv cut off from Novak made for 4s. Works well by pulsing the throttle, then I have a light mounted that will begin to glow as well.
                          I have also dunked the Turnigy packs with no ill affect. Just made sure to let them dry for an evening. One other thing.....I "seal" the packs with high temp hot glue. In the future I may start dipping them in a coating material that is used for tools.
                          • BBZRacing1
                            • 33
                            Thank you for the help guys
                            • BBZRacing1
                              • 33
                              Can I use the V Balancer on these packs?
