setting up the esc
  • rcboatfan
    • 253
    setting up the esc
    so i got my sv27 the other day and i had to change the connectors to traxxas ones and i just got them today, any ways i turn one the stock transmitter and plug in the batteries, 1 beep, full throttle, onother beep, let go of the throttle and then alot of othe beeps. i did that and it all went great! but then i un plug my batteries and re plug them in and i the esc just plays beeps one after the other and just the steering works but no throttle? whats wrong? and another thing i want to know is do i need to do anything to program the esc or anything after i install my spectrum dx3s? thanks
    SUPERVEE 27 37'' TWIN CAT
  • rcboatfan
    • 253
    anyone?!?!?!
    • sailr
      • Nov 2007
      • 6924
      that esc is usually plug and play. The only thing I can think of is your throttle trim is way off.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • z400
        • 1311
        try reversing your throttle servo from your transmitter.
        Z
        KBB34" Mono - Fast
        ToySport Triton- Not as fast
        • rcboatfan
          • 253
          ok so i have doen what you guys said and its good but now i turn it on and i have mo throttle but i do have steering??? what is going on?? and im using my spectrum dx3s. thanks
          • rcboatfan
            • 253
            Please help!!! I want to run this thing!!!
            • H&MWill
              • 623
              Still sounds like throttle trim is off to me.
              Many issues!!!
              • rcboatfan
                • 253
                hhhmmm ok thanks
                • H&MWill
                  • 623
                  hhhmmm ok thanks
                  Im not saying definately but I cant think of anything else that would do that. Hope you get it straightened out.
                  Many issues!!!
                  • domwilson
                    • 4405
                    From Aquacraft's website: http://www.aquacraftmodels.com/techs...qub17tech.html
                    To arm the AquaCraft SuperVee 27 Brushless power system, follow the steps below:
                    Install fresh "AA" batteries in your AquaCraft transmitter.
                    Turn the throttle trim knob - located on the far right top of the transmitter - fully counter-clockwise (see illustration).
                    Make sure that the throttle servo reversing switch is in the down position (see illustration).
                    Turn the transmitter "ON".
                    Install two charged, 6-cell battery packs in your SV27 Brushless boat. Then, plug them into the ESC (electronic speed control) inside the boat.
                    Listen for a single beep.
                    Pull the throttle trigger all the way back (as if to apply full power). Listen for a single beep.
                    Release the throttle trigger to neutral and listen for the five remaining beeps. Your boat is now ready to operate.
                    If your boat does not beep in the order listed above, re-check the settings on the hand-held transmitter and repeat the steps above.
                    Government Moto:
                    • rcboatfan
                      • 253
                      i did all that
                      • rcboatfan
                        • 253
                        i turnd the throttle trim both ways and nothing is working!!!! i aboustly need this boat woking for the weekend!!!
                        • eboat
                          • Aug 2007
                          • 693
                          When you switched to the spectrum radio (I have the same one) make sure you did not turn the esc plug over when you plugged it into the reciever
                          • rcboatfan
                            • 253
                            which color of wire should on which side of the plug?
                            • H&MWill
                              • 623
                              If the steering servo is working make sure the ESC plug is plugged in the same way. Also hook the stock radio back up and see what you get if it works then you know its something with the new radio.
                              Many issues!!!
