Making a reliable boat...
  • Bubber Jones
    • Jun 2009
    • 14
    I just finished putting together my used SV27. Here's what I did:
    Stripped it down to a hull, including removing the "battery trays"
    The drive line was loose, so I aligned it properly and epoxied it in place.
    Coated all wood with epoxy
    Installed OSE trim tabs (with silicon)
    Reinstalled the rest of the other hardware (with silicon)
    Installed OSE drive cable
    Installed 40x52/3 Prop
    Filled hull space with pool noodle stuff
    I'll be using Zippy 2s20c5000 batteries
    So I'm down to the water lines and I'd like to replace those. I've got an entire spool of this:
    Venom 50' Ultra Fuel Tube
    It appears that it may have a bit smaller id than the water lines on the boat, but I don't have a way to accurately measure. Is this good to use, or is there something else that I should use?
    And of course, what did I miss?
    I'm a complete noob (other than my Villian EX with the OSE props)
    Thanks
    Dan
  • Bubber Jones
    • Jun 2009
    • 14
    Tap tap... Is this thing on?
    • Diegoboy
      • Mar 2007
      • 7443
      Do you have any pics to show? it would out alot
      • MonsterMaxx
        • Jun 2009
        • 50
        That blue line will be just fine
        put a coat of wax on that filthy thing and put some kool stickers on it
        you need the other turn fin and that prop's not going to work, you need to put it on my ul1 :)
        5 cars, 9 trucks, 2 scale, 1 crawler, 2 boats, 8 helis, 3 planes, 1 jet, a hydralic endloader, and that’s just the ones that are rtr or nearly so, not even counting the ones in a bucket, ugh, I got it bad.
        • z400
          • 1333
          I dont suggest running a nitro fuel line.
          A specific spool of water cooling line or line for a gasoline engine will be much more suitable.
          You WILL NEED the inside diameter of the cooling line to be as big as you can get it.
          Z
          KBB34" Mono - Fast
          ToySport Triton- Not as fast
          • Bubber Jones
            • Jun 2009
            • 14
            Thanks Sean. Do you have a link to something appropriate?
            • MonsterMaxx
              • Jun 2009
              • 50
              fyi: bubber jones is my 'friend in Atlanta' and I'm at his house this weekend, my post was bustin on him, that's all.
              • z400
                • 1333
                You can use Air Line for fish aquariums which can eb found at pets mart and wal-mart.
                There is also water cooling line sold here at OSE.
                http://www.offshoreelectrics.com/pro...g-7%2F32-clear
                And here is the airline tubing i was talking about at Pets-Mart
                PetSmart pet stores offer quality pet products, pet food, and accessories. Find pet service locations for pet grooming, dog training, and boarding.
                Z
                KBB34" Mono - Fast
                • Bubber Jones
                  • Jun 2009
                  • 14
                  Wow!
                  Thanks Sean....
                  Well, we took our new bundles of joy to the pond today. I knew these things were going to be faster than my old Villain EX, but holy jeez... This thing hauls. The first time I got on the throttle, the prop was cavitating, then it started to hook up and got faster... and faster... and faster... and well, you get the idea. Blistering. MonsterMaxx's UL1 was even faster... What a blast!
                  My SV Poser (I'm the photographer, so no action shots of the SV)...
                  MonsterMaxx's UL1
                  MonsterMaxx trying out the UL1's 4x4 capabilities...
