Is it me or is my SV sitting too low in the water??
  • 03civic1
    • Apr 2009
    • 95
    i did a float test it the tub tonight to check if the boat was sitting ok cause i moved the batteries up alittle bit andmaybe its just me or is my boat sittin really low???
    • 9481
    Looks like mine bro!
      • 9481
      how it looks at 40MPH !
      • 6S HYDRO
        • 1325
        looks right to me, ps use a antenna cap over the stock water pickup. it will stop the water from flowing thru and causing drag
        • z400
          • 1333
          Why do you guys that run 2 pick ups.. Not take full advantage of the first/stock pickup!?
          If i had 2 pickups, my motor would have a fresh source of water and so would my esc.
          Z
          KBB34" Mono - Fast
          ToySport Triton- Not as fast
          • 6S HYDRO
            • 1325
            also, did you ever find a match for the paint. i want to get some money to ya so you can get to work on paintin that blue one.
            • 6S HYDRO
              • 1325
              that stock pickup sucks. it doesnt pump water in the staights and only a little when turning right. the traxxas pickup flows so much water its un neccesary to run two. i was going to run it to the esc but dont want to chance overheating it ( i run 5s regularly on stock esc) havnt had a prob with the single traxxas pickup
              • domp444
                • Jul 2009
                • 901
                Hey! Where'd you get the new rudder?
                SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
                • BIGDG357
                  • 270
                  I doubt this guy will answer you, but this looks like the stock rudder with the blue anodize removed
                  • z400
                    • 1333
                    Where are you seeing a new rudder at?
                    And the guy your asking the question to is supposed to be dead right now..
                    Z
                    KBB34" Mono - Fast
                    • domp444
                      • Jul 2009
                      • 901
                      Oh I thought it was an upgraded rudder. How do I remove the blue anodize? Does it improve the performance?
                      Why is he supposed to be dead? :O haha
                      • BIGDG357
                        • 270
                        I used regular oven cleaner on mine just spray it on( remove the hardware from the boat of coarse) and rinse it off it may take a few times but it will get it off. It seems this guy owes people money and or merchandise, I guess when this sort of thing happens people convenietly die
                        • domp444
                          • Jul 2009
                          • 901
                          Oh alright sounds cool. What do you use to make the back of the boat water tight? Sometimes I feel like the water comes in through the back such as where the rudder rod goes into the boat. I was thinking of putting epoxy on the transom from the inside. Good idea?
                          • Jesse J
                            scale FE enthusiast
                            • 7818
                            Come on David, give us a little shout out. Where'd you get that rudder, I'd like to know too...
                            Boat still for sale?
                            "Look good doin' it"
                            See the fleet
                            • BIGDG357
                              • 270
                              the water is probrably coming in from your hardware as mine did.Remove your hardware and put a bit of silicone under the hardware and remount, this worked for me.Another thing i have added is an autobailer that you can get here at OSE this will help get water out of your hull if it does get in.
