Tips for my modified SV...
  • tommyboyen
    • 20
    Hello
    I've had my SV for a month or so now and ran it completly stock, with DTX4200 6cells batteries and a Grimracer 40x52 3 blade propeller.
    I have now modified it with a Ammo 2300 motor, CC BEC and runs it on EP4500 7 cells. I also replaced the propeller with a K48.
    The boats seems faster and the acceleration is awesome, but I feel it could have a bit higher topspeed. The batteries also got very hot, like smokin' hot....? Any tips on what to do next?
    I also added the OSE adj. trim tabs an the left turn fin. This really made the boat superb to handle.
    __________________________________________________
    Tommy
    SV27 / Key West / Cobra / DF 29 / Outrage
  • bigpapa
    • Apr 2009
    • 2531
    Sv's are known to be Nicad Killers need to get 4000 to 49000 lipo's or higher, 7.4 volt
    25 to 30 c burst and the boat will be a monster hope this helps.............
    THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
    CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
    • tommyboyen
      • 20
      Like these?
      http://www3.towerhobbies.com/cgi-bin...?&I=LXWRA9&P=7
      Or these?
      http://www3.towerhobbies.com/cgi-bin...?&I=LXWRB0&P=7
      I thought maybe 11.1v might give me more bang....
      I'm aslo going to install the CC Hydra 120 ESC and upgrade the cooling-system just to be on the safe side....
      PS: I run NIMh batteries today, not NiCd.....
      Tommy
      • bigpapa
        • Apr 2009
        • 2531
        same with the NIMh also, u can run 11.1 with the hydra 120 would not do it with the stock esc
        THOSE BATTERY'S ARE AWSOME LIPO'S
        • nate
          • 1702
          If you run two 11.1v batterys in series on the CC120, Id make sure you start with a smaller prop.
          22.2V Will be killer and your ESC If you use the props that you have now.
          LMT
          LehnerMotorenTechnik.com
          • bigpapa
            • Apr 2009
            • 2531
            YES OLD GREAT ONE. one lol trun fins look awsome worked on bj26 converting to wire drive will send pics of sv tonight and test after work today
            • nate
              • 1702
              Sweet thanks looking forward to seeing them in a vid too haha lol
              LMT
              • 785boats
                Wet Track Racing
                • 3423
                Tommyboyen.
                You do realise that you will be trying to spin that Ammo2300 at about 51,000 rpm on 22.2 volts (6s).
                Not sure it's going to like that, & the prop size you'll need, to keep the smoke inside everything, may be too small to get the boat going.
                The K448 in my opinion is way too big for the Ammo on 12 cells. Hence the smokin' hot batteries.
                Try an Octura M640 or M642. The Grim Racer 40mm x 55mm/3 blade is also a good one.
                Those props will also be great on 4s lipo. Not 6s (22.2V) though.
                All the best.
                Paul.
                • tommyboyen
                  • 20
                  Thanks for the replies, Im pretty new in this hobby and need all the advice I can get
                  I ordered some 2s 5000mAH 30C from Poly RC and I also ordered a hydra120, a feigao 8xl plus some cooling stuff from OSE. Hopefully this will make my sv move.
                  Tommy
                  • bigpapa
                    • Apr 2009
                    • 2531
                    look at my superve in this forum it's on 4000 28c lipo's
                    • tommyboyen
                      • 20
                      Took the sv out for a spin today, but when I hit throttle it runs very uneven. If I hold the throttle all in it only goes on/off/on/off/on/off....... I took it out of the water and it worked just fine, but when I put it back in its the same thing all over again.
                      Any suggestions on whats wrong with it folks???
                      Tommy
                      • bigpapa
                        • Apr 2009
                        • 2531
                        see if the prop and drive dog and cable coupler are tight
                        • tommyboyen
                          • 20
                          all the mecanical seems to be ok, i thought more in the ways of a burned motor etc.
                          Tommy
                          • bigpapa
                            • Apr 2009
                            • 2531
                            was water coming out the weep hole
                            • tommyboyen
                              • 20
                              yes...
                              Tommy
