My VERY Fast SV27!!!!
  • nate
    • 1702
    Ok so Here's my new SV27, I have bought and Installed the Feigao 12l... Running the stock ESC, and an X442 Octura prop. I pulled up the wood battery trays, and layed down some thick Velcrow, Replaced all the fuel tubing, and used a set of OSE trim tabs and a few other mods.
    The video that is shown here was about the 4th time it was run full throttle, This was less than a 5min run because I got very nervous after the flip in the video, Everytime I pulled the trigger it lifted into the air. I don't have a clue as to what the speeds are, but with a few things done, and a bit of trimming it should break 45mph easy!
    Pic's and Video!!!!!
    LMT
    LehnerMotorenTechnik.com
  • nate
    • 1702
    LMT
    • AZpdljumper
      • Apr 2009
      • 98
      Looks like a shift forward with the batteries is in order. That boat was skipping
      like crazy. I did a triple barrel roll yesterday after hitting my own wake broadside
      but ended up shinny side up. Sometimes I amaze myself. Got a charger on order and lipo's to follow. Let the crazyness begin in Arizona.
      SV 27 , Mean Machine, Prince 26,Vac-U-Pickle
      • Rumdog
        • 6667
        You may need to angle the strut down a little! that's a rocket man!
        • nate
          • 1702
          Doin another run hold on and ill answer q's!
          LMT
          • z400
            • 1333
            Thats a monster! 12L egh?!
            What do you think it would do with a 642?
            Z
            KBB34" Mono - Fast
            ToySport Triton- Not as fast
            • Rumdog
              • 6667
              I think the esc would with a x 642!
              • nate
                • 1702
                No I believe it would work.. In short burst's... SAW passes, then let it set and cool down after running it with a x642. It would be considerably faster on an x642, but Id rather keep it on the safer side and run low 40's ... and still do a few oval laps without all the extra heat.
                I got my cousin to take another video, there very short because the memory on my card for my digital camera is low.. so sorry for the short video's.
                So I guess running this setup is faster than stock yes, but it does run a bit hotter on a 442, I first started with the x438 and did none stop passes beating on it after a few tests and it seem to run great, but I also ran double pickups...
                Im about to build another water pickup for the motor...
                The motor wasn't that hot, but the ESC was a bit warm after 5-6 laps.
                I also pulled the batterys forward and tryed a few diffrent places...it help very little, so I did the most adj. with the trim tabs... it was still abit off but what do you exspect with that much power lol
                Here's another video, Enjoy!!
                Here's Mine!
                LMT
                • obrien
                  • Nov 2007
                  • 1320
                  how far forward did you move the batteries. My old SV ran 52mph with an ammo 2300 hydra 120 and a 645 prop. I actually crammed a pair of 4s batteries in the boat to give it the weight it needed to stay on the water. I never did this, but I know of alot of guys actually adding weight forward in the hull to help keep the boat settled. You don't want to get the batteries too far forward becuase the boat will be pretty easy to spin out in a turn with the CG too far forward.
                  Another suggestion, take the tongue off your prop.
                  • bigpapa
                    • Apr 2009
                    • 2531
                    Nate's rocket
                    sweet boat my friend, its a rocket
                    THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
                    CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
                    • nate
                      • 1702
                      I have an m445 and an m442, maybe try them out and see what happens??
                      They were pulled forward at most an inch from stock settings, and one lap it did
                      spin around in the turn, so I brought it in and set the tabs..it performed alot better with
                      trim tabs set than batterys re-located.
                      LMT
                      • nate
                        • 1702
                        Haha yea its OK for now, oh by the way I sent out your turn fins and added an extra as well.
                        LMT
                        • bigpapa
                          • Apr 2009
                          • 2531
                          tks,posted a few pics of my boats let me kow what ya think
                          • nate
                            • 1702
                            Were at?...
                            LMT
                            • bigpapa
                              • Apr 2009
                              • 2531
                              ul1 sv and boat threads
