55mph SV27 SETUP?
  • nate
    • 1702
    #46
    I tried...the waters dark and I tried to fell for it but no luck....
    LMT
    LehnerMotorenTechnik.com
    • Jeff Wohlt
      • 2740
      #47
      Go get a cheap magnet in the fishing area and hook it to a piece of ligh line and drag it around and you should find it with a little luck. While at Walmart spend $30 on a inflatable 2 person boat. You are lucky as that is still very cold water.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
        • 9481
        #48
        Bummer, sorry to hear that..
        Let us know how your red one runs when you finish it!
        • nate
          • 1702
          #49
          Yeah thats not a bad Idea using a magnet lol..Im might try that when it clears up...just got to find the spot its at lol
          LMT
          • Jesse J
            scale FE enthusiast
            • 7818
            #50
            So, you tellin us you took out that stupid blue flotation in the waterproof boat? AND you lost that killer X447 prop with the cute little prop nut? AAAAANNNDDD you sank the boat? Good thing this happened on the bruised yellow boat rather than the 55mph build...
            I have done the swimming after lost drive lines....... to no avail. good luck with the magnet.
            "Look good doin' it"
            See the fleet
            • nate
              • 1702
              #51
              Yea I was just gunna run it one time lol then its sinks lol
              LMT
              • Jeff Wohlt
                • 2740
                #52
                The mags I am referring to can pick up about 20# under water. They are also very small.
                Just throwing it out and dragging may get it back but you really never know where it is....if came out spinning it can drive its self along. 12' of water is not bad. Hell, you may find other things as well! For finding boats this one is pretty good but tere are better.
                Agen Sbobet88 resmi di Indonesia menawarkan pasaran Handicap dan Mix Parlay paling fair yang mengacu pada pasaran Sbobet dunia dan bisa diakses kapanpun melalui situs Agen5758.
                www.rcraceboat.com
                • nate
                  • 1702
                  #53
                  Well Im alittle low on money to spend so much more than whats lost just to find alittle more than $50 bucks worth...I mean it sucks but also that the Park is very strick on the time limit you get on these little boat they offer, and they wont alow to bring your on boat or whatever.
                  The boats are docked at the end of the lake around 1/4th mile in the corner...and the it take forever to get out to the other end were the boat sank, It took over 30 minutes just to get there, and its 10$ buck for 30min of use lol dumb huh. So ill just take my losses on this one for now. Thanks anyways Jeff for trying to help out man!
                  LMT
                  • nate
                    • 1702
                    #54
                    Ok guys heres whats up yo! lol
                    So Iv been thinking about buying a Hydra 120...
                    Im hoping the Stock AQU ESC will take the Neu30c's 4s2p on the Feigao12/L.....
                    So what Iv done is.......Well....you get the idea lol.......................
                    LMT
                    • nate
                      • 1702
                      #55
                      Still got to do another coat of JB Weld,
                      do some sand work...then paint it...
                      Ill be the first paint one I think....lol
                      LMT
                        • 9481
                        #56
                        That's awesome, I hope it works..
                        • nate
                          • 1702
                          #57
                          Maybe it will, Im gunna run another aqu esc with the stock cooling for 3-4mins check temp then swap over and try this one.... its should work...
                          LMT
                          • nate
                            • 1702
                            #58
                            LMT
                            • nate
                              • 1702
                              #59
                              Well I went ahead and bought a Hydra120, and Im doing a diffrent setup on this red beast...
                              I also ordered a Neu 1515 1.5y 1500kv with the water jacket ect.
                              Ill start out with an x440-then jump to an x442 if its possible.
                              Maybe Ill see more than 47mph on 4s2p with this setup....
                              What speeds do yall think ill see....
                              LMT
                              • nate
                                • 1702
                                #60
                                The parts from OSE finally arrived, its almost finished....Ill post more progress later today!!
                                LMT
