is this prop that same as the stock sv27 prop? If so would it perform any different? I was told it would be better but it looks the same just metal?
GrimRacer 40x52/3
not the same.....that's the one Grim Racer recommends and its a 3 bladeOriginally posted by brad65 View Postis this prop that same as the stock sv27 prop? It so would it perform any different? I was told it would be better but it looks the same just metal?SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
Has it been sharpened and balanced? It should be for best results and to save bearings from wearing out fast.Originally posted by brad65 View PostWell it's on and I'm tring my new sv out tommorrow. I can't wait I hope this prop is alittle better then stock cause the stock one sucks for getting on planeIMPBA 20481S D-12
Well I got to trim out the sv today. I'm not fully happy it felt slow maybe 30 mph. This is a full marine greased and I check for binds and 0 deg prop shaft angle. Also I opened up all the water fittings and rudder holes. Humm it felt faster with the stock prop. I'm surprised it wasn't faster with two 5600mah 35c 45burst 2s lipo's, also I had the cg at 8.75 from transom. Trim tabs were moved just down enough not to bounce the boat. I think I need a better prop? Is there a direct link to a web site were I can order a prop that needs no work just install and go? I'm not looking to sharpen and balance a prop if I don't have to. Any help guys?Pro Boat Apache 24 Brushless, Thunder Cat 31
AquaCraft SV27, AqauCraft UL-1
Brad65, When my SV was stock I had the best performance from an Octura M-445. Gps at 43 mph. If you don't want to spend that much to test a prop look on the OSE site at these, Product ID: grp-2317.42, Graupner K Series 42mm and the Product ID: grp-2317.45 Graupner K Series 45mm. For the price you can test them and then purchase a metal one when you find the right one. You also mentioned greasing the flex shaft. One word of warning, do not use any kind of a silicone bassed product. One of our club menbers used one and he lost about 7 mph right away. Best grease for the boat is Grim Racer Speed Grease. If per chance you used a silicone bassed grease remove it and replace the teflon liner.
Very interesting a you guys. I like the idea of the cf 42,45,48 props on this site to try out like u said for the price how can u go wrong thanks guys. I'll get this sv27 up to speed soon. I got a friend with a nitro sv that wants to take on my brushless sv, well I need a prop first LOLPro Boat Apache 24 Brushless, Thunder Cat 31
skibo2 On my bj26, I'm using blue marine grease from my grease gun that I use on the wheel bearings of my BIG BOAT but not sure if it is silicon based. I guess I'll check tomorrow. Why, too thick? I'm using air gun oil in my Traxxas Villian as it has feeders
When I first started in RC Boating I used the blue marine grease from my full size boat on my Enforcer gas boat and I noticed the speed was slow and the shaft felt sticky to turn by hand. I then cleaned the grease off and regreased it with car automotive wheel bearing grease and the shaft turned much easier. The boat picked up a lot more speed. At that time I was advised by an old timer in the sport to use the speed grease from Aquacraft and have been using it ever since. I own 9 boats, FE and Gas and use it in all of them and have never had a shaft failure. I grease the shaft after every outing. The guy in our club that used the silicone based grease was using a grease put out by Traxas for cars.Originally posted by bwells View Postskibo2 On my bj26, I'm using blue marine grease from my grease gun that I use on the wheel bearings of my BIG BOAT but not sure if it is silicon based. I guess I'll check tomorrow. Why, too thick? I'm using air gun oil in my Traxxas Villian as it has feeders
