Hey guys I've flipped over my sv27 twice already and Im getting the hull filled with water even when I taped here up. What can I do to have an easy openalbe water proof top on these bad boys?
how to make the hatch water proof
Originally posted by brad65 View PostHey guys I've flipped over my sv27 twice already and Im getting the hull filled with water even when I taped here up. What can I do to have an easy openalbe water proof top on these bad boys?
Is the antenna still in the stock location?Steven Vaccaro
guess it would have costed more LOL. Its just sad it leaks am I the only one?Originally posted by sewerpit View Postnothing, live with the tape, it works best. if you come up with something better let us all know. good luck enjoyPro Boat Apache 24 Brushless, Thunder Cat 31
AquaCraft SV27, AqauCraft UL-1
The hatch is supposed to be an easy fix
lay a bead of clear silicone caulking in the groove for the hatch on the boat...then take some clear plastic sandwich wrap and wrap the hatch cover with it...then set the hatch into its groove of the boat and clamp it shut....let the silicone dry completely....when it dries it wont stick to the sandwich wrap and you can take it off the hatch...DONE
then deal with the stock antenna hole..seal it upSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
Wow that sounds like a great fix. Thank youLast edited by brad65; 04-13-2009, 01:23 PM.Pro Boat Apache 24 Brushless, Thunder Cat 31
here is a fix for the latch alsoOriginally posted by brad65 View PostWow that sounds like a great fix. Thank you
http://forums.offshoreelectrics.com/...ight=hatch+fixSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
