sv hopping badly in turns
  • 6S HYDRO
    • 1320
    need some help re-setting up my sv to turn. had it set up to say in the water on 5 cell speed passes now i cant get it to turn like it used to.
  • riverside4
    • Jul 2008
    • 49
    So your running 5 cell lipo i assume if so witch side do you have the 3 cell on i would try it on the left side of the boat and try to move them forward. Sound like your COG is off.
    • 6S HYDRO
      • 1320
      I was running 5 cell before, and it was on the right side. But now is on 2x 2s with battery trays removed and lipos moved upward slightly.
      • z400
        • 1311
        How far is upward slightly?
        Lipo's are much lighter, they will need to be moved up towards the front a little ways
        Z
        KBB34" Mono - Fast
        ToySport Triton- Not as fast
        • 6S HYDRO
          • 1320
          well i have velcro way up there, so how far north of the orig location should they be.
          • riverside4
            • Jul 2008
            • 49
            With lipos 1/3 of the pack towards the front of the motor plate try there to start.
            • 6S HYDRO
              • 1320
              so 1/3 of the pack in front of the motor plate
              • z400
                • 1311
                Yes
                Z
                KBB34" Mono - Fast
                • 6S HYDRO
                  • 1320
                  so this issue is only caused by cog? seems like when i played w/ strut depth it changed the effects but would still hop. could it be caused by bent hardware? i let my buddy drive it and it went upshore at about full power- but everything seems dead straight. i did have to do some fiberglass work.
                  • skibo2
                    • 35
                    Hopping in the turn at full speed is quite common in the SV. We have 6 boats in our club and they all hopped in the turns. The problem, as we found, is the turn fin is too short. We used the original turn fin as a pattern on a piece of .064 aluminum plate and leghtened the fin by one inch. Some of the guys also bent the fin so it hangs straight down instead of on an angle. I personally like the fin straight down. I am running a Fiegao 8XL motor on 30C lypo's and running in the high 40's and can make a right hand turn at full throttle hardly any hop. There is some, in rough water, but nowhere near what is was with the short stock fin.
