Octura Flex Shaft
  • Fast Guy
    • 135
    Octura Flex Shaft
    I just recieved a couple unassembled flex shafts from OffShore Electrics to use on our 2 SuperVees. I noticed that the propeller shaft is much shorter than the original SuperVee shaft. Is there still enough shaft in the bushing for proper support. The original shaft had about 2 1/2 in. in the bushing while the Octura is only 1 1/8 in. I'm not sure how long the bushing is. Thanks.
  • Jeepers
    • May 2007
    • 2050
    I dont think there will be a problem with that, the stock bushing is probably long enough if its supporting that longer shaft, I use the octura shafts as well, they are much shorter than the hughey shafts that I was using and they work fine.
    • Steven Vaccaro
      Administrator
      • 8932
      No worries, there are LOTS of these in sv's all over the world. Less shaft, less friction. On the sv the shorter shaft is also a plus because with the stock shaft and strut, the shaft minimizes the amount of angle you can put into the strut.
      Steven Vaccaro
      • Steven Vaccaro
        Administrator
        • 8932
        Oh, I forgot. When assembling the cable make sure everything is grease/oil free.
        Steven Vaccaro
        • Fast Guy
          • 135
          Thanks Steven. I'm going to use Loctite 603 to assemble the cable to the propeller shaft. Whats the best way to cut the flex shaft? Thanks again.
          • Mich. Maniac
            • 1456
            I used a dremel with cutoff wheel, works great. that loctite is unreal how well it works. I bought that and some primer from my local distributer and it was about 45.00. Kinda steep but after I used it, well worth the bucks. I havent tinned the ends of my shafts yet I think I need a hotter iron.
            • avengersteve
              • 395
              i have the cable from her, in my sv27, and it helps soo much with angle adjustments
              restoring the collection
              • SJFE
                • 4867
                To attest to longevity. I have run the OSE upgrade cable and shaft since day one. I have had no issues what so ever of any kind with it.
