lost my prop shaft - will a normal 3/16 prop shaft work for a replacement?
  • engineerjoe
    • Sep 2008
    • 38
    i lost my prop shaft from my SV27 with stock hardware (sacrificed to the lake gods ), the drive cable was still there but the solder broke.
    will this (http://www.offshoreelectrics.com/pro...oct-oc150L-24c) work fine with the stock hardware on my boat?
    also will this (oct-oc6150ps) prop shaft work with the stock flex cable (that i still have for a spare?)
    thanks guys.
  • engineerjoe
    • Sep 2008
    • 38
    found my answer to the first question by searching for the Product ID:
    http://forums.offshoreelectrics.com/...oct-oc150L-24c
    • DISAR
      • 1137
      Hi,
      This page has all the SV parts and upgrades
      http://www.offshoreelectrics.com/products.php?cat=52
      You can either get this one complete with no cutting no soldering required
      Product ID: ose-svcable
      OSE Upgraded AquaCraft SuperVee Cable
      or the one you mentioned but get it assembled and also note that you will have to cut the flex using a Dremel tool preferrably. If not done before better buy the first one because when cutting the flex you can destroy it
      Product ID: oct-oc150L-24c
      http://www.rcfastboats.com/
      • engineerjoe
        • Sep 2008
        • 38
        Originally posted by DISAR View Post
        Hi,
        Thanks for the response, I have assembled a couple flex cables for my gasser but not on the SV yet. I'm on a tight budget so I wanted the unassembled for the cost savings. I did end up buying the two products mentioned in the first post.
        • engineerjoe
          • Sep 2008
          • 38
          Assembled the flex shafts last night, should be running this afternoon.
