Mods to my SV
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 439
    Well put Tim
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
    • bustitup
      • 3072
      fruity
      do you have a build thread on that esc cooler?...... I like that
      • z400
        • 1333
        Originally posted by bustitup View Post
        fruity
        I tried getting him to build/sell me one but he said it wasnt worth it.
        Dont quite know what that means.
        Z
        KBB34" Mono - Fast
        ToySport Triton- Not as fast
        • Fruity
          • Jan 2009
          • 189
          ESC Cooling Plate
          Guys,
          the cooling plate on the esc is just a block of 12mm thick aluminium plate, then it has the water ports drilled through it, the water travels in a 'S' pattern through the plate, so the extra ports to get the flow path correct are just blocked with grub screws loctited in. I drilled all of the ports quite large (6.8mm) and blocked those from the back with M8 grub screws, then just used the some M5 fittings for the inlet & outlet. The rason for the bigger holes is more surface area in contact with the water = better cooling.
          I will grab some more photo's and post them when I am down the shed later.
          The reason it is not worth it is it is a really simple item to make & I am in australia so it is not worth posting it half way across the world.
          Cheers...Tim.
