52.4 mph sv
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 439
    52.4 mph sv
    Finally cracked the 50mph barrier or as us Aussies say 80km mark. Running an 8XL with an ETTI 150amp speedy 2 x 2s 25c 5000mah lipos. First run with CF 45mm prop 47.6 mph . then 2nd run , ran a Prather B230 & gps 52.4 mph .Dont know how that dude cracked 58.4mph ,ive tried the same set up and cant get close !!!1 Every thing ran cool no heat issus , running 2x SV27 silicon water jackets on the 540XL motor kept it nice & cool ....
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
  • Xzessperated
    • Apr 2008
    • 3063
    Well done Scoota. That is a very good speed.
    • line6
      • 510
      Bat temp. and good lipos. I ran low 50's a few times and thought something was wrong you could tell it was off just by sound. I did that a couple times at the end of the day, and it left me wondering. Then i had time to run again after a low 50ish run i charged the batteries up and warmed them up some more and ran a high 57.
      • Steven Vaccaro
        Administrator
        • 8932
        Anywhere in the 50's is boogieing! good job!!!!
        Steven Vaccaro
        • line6
          • 510
          Its also a plane waiting to take flight
            Adding 12-18 ounces of lead at the CG will keep the model on the water and make it less prone to take off. Sometimes you go faster by adding weight.
            • scoota
              FE DOWN UNDER
              • Dec 2008
              • 439
              Thanks guys might try adding some weight i found my self backing off a lot cause it was unstable at that speed !! as for the batteries im running flight powers EVO25 V-Powers 4900mah & Intellect 5000mah lipos witch i warm before running ....
              • Fruity
                • Jan 2009
                • 189
                Sv 27
                Scoota,
                I see your in Australia, me also, I have just ordered a SV 27, and a couple of 2 S lipo's for it, do you charge your packs as one, ie, balance all 4 cells?
                I am looking at chargers and are just a bit unsure of how to wire the balance lead.
