parrallel or series
  • sewerpit
    • 139
    parrallel or series
    is the stock sv set up in series or parallel for power to the motor and esc
  • yudruln8
    • 159
    i believe it is series
    • H&MWill
      • 680
      It is series.
      Many issues!!!
        It depends on the packs you will use. If you use two 2S packs, then you will wire them in series for 4S1P. If you use a single 4S pack, plug in directly. If you use two 4S packs, wire them in parallel for 4S2P. Two 4S/3300 packs should fit, but I don't know if the weight difference will matter much - run time would be loooong.
