speed brake
  • jlr3rd1
    • 270
    speed brake
    hey :) i just got a supervee brushless and i think the speed brake is off?? does any one know if this unit has that feature??? if so how to turn it back on? i know my blackjack has that feature:) thks jim
    2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
  • Boatman
    • 875
    Not sure if the esc actually has that feature but if it does or does not I think all you can do is go through the initial setup procedure. Full throttle, full brake, neutral. Or however it goes. its been awhile. I dont see the need for "speed break" anyway.
    • Ub Hauled
      • 3051
      I have an Aquacraft system.. no such feature. The BJ has a different ESC (more options).
      • jlr3rd1
        • 270
        ok cool thks
        • ice329
          • 797
          The SV does have a break, weather its called a speed break I dont know. You know the break is on if when you arm the boat you will hear like 4 double beeps instead of 4 single beeps. The break should problt be off, at least this is how I set um up.
          • jlr3rd1
            • 270
            ok i thought it did , so how do you turn on . i know my is off . thks
            • ice329
              • 797
              There is a thread that tells you if you do a search, just spell it right not like I did.... but if I remember its something like turn the radio on and pull or push the throtal then plug in the packs while keeping the trigger pulled or pushed... something like that. I have it printed out someplace if you cant find it or someone dont post it for sure.
              • Rex R
                • 1007
                default setting is off. for boats, in particular fast electric boats, brakes are ineffective when applied to the prop. then too the use of the brake setting may actually cause damage to the esc(from the back emf). best to simply leave it off.
                • jlr3rd1
                  • 270
                  really ok ?? so just let off the trigger alot sooner. so should i disable the brake on my blackjack to then? thks this is all new to me?? but haven fun
                  • jlr3rd1
                    • 270
                    hey never seen that thread on the brake on /off
                    • ice329
                      • 797
                      Here is the thread... http://www.offshoreelectrics.com/for...ighlight=brake
                      • jlr3rd1
                        • 270
                        awesome thks !!
                        • Electro
                          • 18
                          At the speed that the boat is going if you apply brake , the shaft cannot hold up to that remember the shaft is twisted in one direction if you brake it will probably unwind.
